How to clean stained exhaust pipe?
- The_Head
20 Feb 2011 16:53 #432179
by The_Head
How to clean stained exhaust pipe? was created by The_Head
My KZ250's exhaust is stained. Here is a pic:
I need a recommendation on how to clean this up.
So far I have tried: 1. steel wool and wd40
2. chrome polish by turtlewax
I have not had any success so far. It's really bugging me. I want it to look nice or I'm going to chop it off and use some kind of stock harley muffler.
- Thank you received: 2829
20 Feb 2011 17:03 #432182
by 650ed
Replied by 650ed on topic How to clean stained exhaust pipe?
It looks like it's been burned with battery acid; if so there's no way to clean it as the chrome is etched. Check your battery vent to make sure the overflow tube is attached and routed correctly or the same thing may happen again. Ed
- PLUMMEN
- Thank you received: 104
20 Feb 2011 17:18 #432193
by PLUMMEN
Replied by PLUMMEN on topic How to clean stained exhaust pipe?
sandblast it or just rough it up and paint it black
- DoubleDub
- Visitor
20 Feb 2011 19:12 #432238
by DoubleDub
Replied by DoubleDub on topic How to clean stained exhaust pipe?
Or a rechrome - I have the same issue on mine.
Or ceramic header paint job.
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
- Thank you received: 20
20 Feb 2011 19:48 #432248
by newOld_kz1000
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
Replied by newOld_kz1000 on topic How to clean stained exhaust pipe?
You could find a used one in decent shape on ebay -- probably cheaper than a re-chrome. Or buy a used aftermarket exhaust, although that might require a re-jet depending on how much less restrictive it is.
If you do find a used one, you could sell your bad one cheap to offset the cost of the better one. Just an idea. Some folks on a tight budget buy parts that are cosmetically shot but functional.
- Thank you received: 1656
21 Feb 2011 06:02 - 11 Feb 2013 12:59 #432316
by martin_csr
Last edit: 11 Feb 2013 12:59 by martin_csr.
- austin3119
- Thank you received: 7
21 Feb 2011 21:13 #432592
by austin3119
Replied by austin3119 on topic How to clean stained exhaust pipe?
Rattle can BBQ paint, ceramic coat, JET-HOT or re-chrome.
I tried a bunch of cleaners as well. All I did was dull the chrome.
- The_Head
23 Feb 2011 16:55 #432985
by The_Head
Replied by The_Head on topic How to clean stained exhaust pipe?
I'm not going to paint it black. I am seriously eyeing a Harley muffler though. There are KZ250 pipes on Ebay, but they are $99 usually.
- PLUMMEN
23 Feb 2011 17:03 - 23 Feb 2011 17:11 #432989
by PLUMMEN
you might be suprised how good it looks with the whole thing painted black
this header was actually an old beat up chrome piece of crap off a basket case kz i had laying around,roughed it up painted it black and threw it on.
Last edit: 23 Feb 2011 17:11 by PLUMMEN.
- hocbj23
- Visitor
23 Feb 2011 17:16 #432992
by hocbj23
Replied by hocbj23 on topic How to clean stained exhaust pipe?
Try a Mother's polishing ball attached to ur drill and a product called White Diamond metal polish.It took 20 years of crud off a Yoshi aluminum can I found and made it look
like chrome. As has been stated above if the can is acid etched, may not be a lot u can do.bj
- The_Head
23 Feb 2011 18:10 #433011
by The_Head
That doesn't look half bad Plummen, thanks for posting the pic!
- DoubleDub
- Visitor
23 Feb 2011 18:19 #433016
by DoubleDub
Just make sure you polish your aluminium like Plummen so they contrast!
