Best streetable kit and cams
- Kz luv
20 Feb 2011 12:03 #432121
by Kz luv
Best streetable kit and cams was created by Kz luv
I have a z1 900 with 1015 cylinders, J head. I am going to put a kit and cams and need to know which is better for a daily rider. I'm either going with 1197 or 1260 pistons. My concern is overheating with the 1260. Also which cams would be best. Not drag racing but want to be a beast mid range. Thanx
- PLUMMEN
- Thank you received: 104
20 Feb 2011 12:53 #432142
by PLUMMEN
Replied by PLUMMEN on topic Best streetable kit and cams
1197 and 410 cams with 29 carbs
- Kz luv
20 Feb 2011 15:53 #432165
by Kz luv
Replied by Kz luv on topic Best streetable kit and cams
Thanx for the response, I assume ur talking about 29mm smoothbores
- PLUMMEN
20 Feb 2011 16:06 #432168
by PLUMMEN
smoothbores or crs would work in my opinion anyway.
remember the j series head drops compression 1 1/2-2 numbers so 10.5:1 becomes between 8.5:1-9:1 which i personally consider the perfect compression for a streetable pump gas motor.
combine that with a 900 crank with that nice topend and youll be breaking a lot of sportbike hearts from stoplight to stoplight on 89 octane gas!
- APE Jay
- Banned
- Thank you received: 58
20 Feb 2011 16:24 #432171
by APE Jay
Replied by APE Jay on topic Best streetable kit and cams
1200 or 1260 with 410s is a good choice With the J head you would want J pistons with a spacer plate. We can put together a package for you.
Jay
Jay
- Kz luv
- Kz luv
- larrycavan
- Visitor
20 Feb 2011 17:25 #432196
by larrycavan
Replied by larrycavan on topic Best streetable kit and cams
Kz luv wrote:
With J head, if you're going to go 1197 kit with k410 cams, which, by the way will make a nice combo... pay attention here...
If you're leaving the head stock & IF you already have 29's, they'll suffice. They outflow a stock J head by about 15CFM.
If you plan on head work and / or you don't already have 29 smoothbores, then skip the used 29's. Get either RS34, RS36 Mikuni's or CRS33 Keihins.
A correctly street ported J Head should outflow the 29's.
With a 1200cc motor and short duration cams like the K410, the motor will easily handle 33mm round slide or 34 - flat slide carbs and deliver good street behavior.
Don't misunderstand, 29's are a good carb but you have to look at the prices they bring for used vs what you can get brand new vs what you intend to do with the head.
Here's the flow information www.flowbenchtech.com/porting/CRH/kz-data.htm
- fukumal
21 Feb 2011 16:49 #432528
by fukumal
Replied by fukumal on topic Best streetable kit and cams
I have the same setup, but I was told that I wouldn't have a problem with the 1260. I'm tryin to build a KING KONG streetfighter slash daily rider. Any input would be greatly appreciated.
