Transmission issue with a 1980 KZ250D
- The_Head
19 Feb 2011 16:19 - 19 Feb 2011 16:20 #431904
by The_Head
Transmission issue with a 1980 KZ250D was created by The_Head
When I am in 4th gear under a heavy load, the transmission will sometimes kick down into 3rd by itself. Sometimes it will go back into 4th, sometimes I have to shift it myself. If I am just cruising it will not do this. It was a little unnerving at first. Unfortunately, it didn't do this when I was test riding the bike, or I would have passed.
The bike has 11K on it so I assume something is worn out. Is this an easy fix or should I just live with it?
Last edit: 19 Feb 2011 16:20 by The_Head.
- Thank you received: 1656
19 Feb 2011 16:24 - 11 Feb 2013 12:58 #431907
by martin_csr
Last edit: 11 Feb 2013 12:58 by martin_csr.
- The_Head
19 Feb 2011 16:28 #431908
by The_Head
Replied by The_Head on topic Transmission issue with a 1980 KZ250D
I will look into the clutch. It seems like it grabs a little soon. Sometimes when I shift it into first from neutral with the clutch handle pulled, the bike will die.
I changed the oil recently though, went with 10W40.
19 Feb 2011 16:34 - 11 Feb 2013 12:58 #431909
by martin_csr
- The_Head
24 Feb 2011 20:16 #433256
by The_Head
Could it be anything else?
