Tapping Cylinder head for helicoil
  • jbrewer73
  • jbrewer73's Avatar Topic Author
17 Feb 2011 20:39
#431422
Well I just got a 78 KZ1000 and realized one of the head bolts is stripped. It is one of the small 10mm on the side. I tried to tap to put helicoil in but when i tried backing it out it came out ablut half way and stopped. Now it is just spinning but not backing out. I bought the kit so i know I am using the correct tap.
Can anyone please help out on what the heck I did or did not do?
Thanks
JB
  • MFolks
  • MFolks's Avatar
Re: Tapping Cylinder head for helicoil
17 Feb 2011 21:02
#431426
Many riders here have used this type of thread repair:
www.timesert.com/
Heli-coils can possibly work for some situations, but as you found out, they will back out if not correctly applied.
  • jbrewer73
17 Feb 2011 21:34
#431428
Let me try and clarify. i dont think i was clear on my last post. I never got the helicoil in. I just tried to tap but when doing so I am unable to remove the tap. I can only back it out half way but then it is spinning. So i cannot remove the actual tap so I can put the helicoil in.
thanks for the feedback
  • MFolks
  • MFolks's Avatar
17 Feb 2011 22:23
#431430
Did you tap the hole dry? Taps need cutting fluid to prevent breakage. I use the black sulfur fluid found at hardware stores for pipe thread cuting.
It's smelly, but lets the tap cut good. Avoid any cutting fluid that can damage Aluminum as this will make for a weak repair.
Tap-matic for Aluminum is a good one, and so is Rapid Tap for Aluminum.
  • Old Man Rock
  • Old Man Rock's Avatar
18 Feb 2011 02:21 - 18 Feb 2011 03:06
#431448
"So i cannot remove the actual tap "....
Assumption is head not removed off engine?
EDIT:
Side 10mm.... Look underneath, my thread goes all the way through top to bottom.... Possibly thread all the way through....
If not, remove head, drill from underside slightly larger then tap... Then re-tap/serts, 12/13mm I guess be one way...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 18 Feb 2011 03:06 by Old Man Rock.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
18 Feb 2011 02:35
#431450
So your tap is stuck? Correct? You shouldn't have to pull the head to re-tap the outer head bolt. If you can't pull it out while spinning it, you may have to revert to what OMR suggested, and then use something like a BigSert, which is used to re-thread holes where the Helicoil has gone wrong.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • DoubleDub
  • DoubleDub's Avatar
18 Feb 2011 05:15
#431466
Maybe a photo?
  • jbrewer73
18 Feb 2011 06:52
#431505
The head is still on the bike. I only used WD while doing this. I did tasp slowly though. 3 turns then backed out a couple turns before continuing. Im not sure how I would get the tap out the other side if I thread all the way through.
I think I might be stuck taking the head off.
