'79 kz650 d2 engine gaskets
- torquey
16 Feb 2011 19:58 #431182
by torquey
79 kz650 sr pods mac 4-1 dynaS dyna coils
'79 kz650 d2 engine gaskets was created by torquey
i'm doing a top end rebuild and having trouble finding gaskets. is there any difference between engines as relates to gaskets?
- Thank you received: 2829
16 Feb 2011 20:36 #431187
by 650ed
Replied by 650ed on topic '79 kz650 d2 engine gaskets
Your best bet is to look at Kawasaki.com parts diagrams to determine which models share which parts. You can then use the part number to find your part at a dealer or the aftermarket equivilent. Ed
- TeK9iNe
- What did you do!?!
17 Feb 2011 05:30 #431220
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic '79 kz650 d2 engine gaskets
The only gasket that you need to buy is a head gasket. The rest can be made with the apropriate gasket maker. Very inexpensive.
Good head gasket. Locktite 1104, or motoseal for base gasket, cheap black permatex for the rest.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
17 Feb 2011 05:59 #431222
by 650ed
TeK9iNe wrote:
Some folks do that, but I do not recommend it. This approach seems especially risky for the base gasket as the thickness of the gasket cannot be controlled by using goo instead of an actual gasket, and the thickness of the gasket affects the distance between the head and the pistons. Gaskets are not that expensive, are much easier to use than goo, and don't pose the risk of having excess goo run inside the engine. Plus most of them (like the valve cover and cam chain tensioner gaskets) can be re-used with no muss/no fuss as long as sealer is not used on both sides. Not flaming, just stating my opinion. Ed
- Bluemeanie
- Thank you received: 14
17 Feb 2011 06:15 #431224
by Bluemeanie
Replied by Bluemeanie on topic '79 kz650 d2 engine gaskets
There is a multitude of gaskets on ebay. Price and quality vary. I believe most if not all 650 gaskets are the same except for the smog valve cover.
Head gaskets.... motors.shop.ebay.com/i.html?_nkw=kz650+h...sid=p4506.m270.l1313
17 Feb 2011 06:33 #431225
by 650ed
- torquey
17 Feb 2011 13:46 #431307
by torquey
Replied by torquey on topic '79 kz650 d2 engine gaskets
thanx folks.
