Straight pipes yay or nay?
- Omaha Rider
Thanks
1978 KZ650 SR D
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Try small steps first to slightly increase the volume. Maybe drill some extra holes in the end cap? Or one off the back/bottom of the pipes?
Start small so you can tailer the sound. You will quickly regret it if you just chop them off.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- dejavoodo41
- Thank you received: 14
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- KZQ
- Administrator
- Thank you received: 1415
I don't want to spend the money on a 4into1 exhaust but want my kz650 SR D to be louder. Can I take the mufflers off of my stock exhaust pipes? Would I have to cut them off? Would it be bad to run the bike like that without rejetting it?
Thanks
No! That would not be a good move!
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- treitz
Regardless of noise level, the jetting will be off.
1979 KZ400 - 2-1 Manifold - Mikuni VM34
- Thank you received: 2829
- PLUMMEN
- Thank you received: 104
not in omaha i wouldnt! :laugh:I don't want to spend the money on a 4into1 exhaust but want my kz650 SR D to be louder. Can I take the mufflers off of my stock exhaust pipes? Would I have to cut them off? Would it be bad to run the bike like that without rejetting it?
Thanks
