- Thank you received: 104
motor assembly
- PLUMMEN
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
- larrycavan
- Visitor
bounty leaves lint in bores,use plain white toilet paper and carb cleaner to clean bores.
Oh you got lint in your navel :laugh: The technical term is "snarf"....
Toilet paper.... My GOD :laugh: In Nebraska thats called the Sears Catalog :woohoo:
All over the state, people went into panic when Sears sent out CDROMS instead of the old paper catalog. The smart ones broke them into pieces and used them as scrapers :silly:
The not so smart ones are.......well, we won't go there right now :kiss:
NEVER handle toilet paper when stoned on Mountain Dew
- PLUMMEN
- PLUMMEN
- larrycavan
- Visitor
ya still extrude porting heads with quaker oats/vodka? :woohoo:
I'm using Grape Nuts and butter milk these days. Nicer finish :laugh:
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- PLUMMEN
dont be yanking my string! :S :woohoo:WTF... Is that a mummy or a tampon? :blink:
- Old Man Rock
Inspect Oil pump for tolerances... See manual.
Inspect clutch basket/fingers now.... See manual.
Replace if required... The clutch plates/springs can be accomplished when assembled but the basket, nope..
Split again....
Get the items listed in this image...
Cases:
3 Bond
Cylinder gasket: Copper Spray...
For gaskets (Thanks Plumi/Lar) for follow the directions for tacking the gasket on both sides... Not on drop/leak....
RTV Gasket for head groove if going to single gasket versus dual... Lar taught me this one as well, slight smearing on valve cover gaskets, gaskets easily pop off after usage when periodic valve/shim adjustments...
Also, get the OEM manual listed for the Z1, 98% same as yours...
kzrider.com/index.php?option=com_docman&...d&gid=434&Itemid=108
Take your time, double check your torques/procedures/manual/notes etc... and you'll be golden....
Good luck...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- larrycavan
- Visitor
That would be a Nebraskan Ninja
To this day, this is still Jimbo's favorite 70's song :laugh:
- larrycavan
- Visitor
Otto's got a new chemical that eliminates all gaskets :laugh:
Assemble the motor and spray it on the outside.... DONE DEAL
It not only eliminates oil leaks, it also:
* Lubricates the moving parts inside
* Cleans the combustion chamber as you ride
* Improves Gas Mileage
* Prevents valves from ever needing adjustment
Not well known to the general public but there's a pendeing patent for "Ottomoniazddpethlhydrogluten"
19.95 for a 16oz spray can. Will do one complete inline four cylinder motor up to 1260cc capacity.
WARNING! Must be used in conjunction with BS34 Mikunis to have full affect
Where the hell are you Otto
- PLUMMEN
as the director of marketing for "OTTOTIVES" automotive/motorcycle additives(tm) nebraska division all i can say is we're rushing to get this great new product to market as soon as possible .Hold Everything!!!
we are currently in negotians with Ron"kz650"co productions and billy mays/anthony whats his name productions to do a late night infommercial to get the word out to the 3:00-3:07am time slot about this great new product!
our fearless leader otto of "OTTOTIVES" automotive/motorcycle additives(tm) will be back just as soon as the bandages are removed and his eyebrows grow back and the epa declares his garage safe! :woohoo:
