- Thank you received: 18
who's running this?
- andy9802gt
- If it tastes that good, eat it yourself.
10 Feb 2011 13:39 #429822
by andy9802gt
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
who's running this? was created by andy9802gt
Hey guys, I want to know who's running the V&H pro pipe and what did you have to do to get it to fit? I know the brake pedal has to be modded but does the frame have to be raked? I want to run the Tarozzi rearsets on my bike so I don't think I'll need to modify anything to get it to fit provided the linkage will clear for the brake pivot. Anybody got any input? Also, I ride everyday if I can, do you think the baffle out of my regular V&H will fit in the megaphone of the sidewinder?
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- hocbj23
- Visitor
10 Feb 2011 13:44 #429823
by hocbj23
Replied by hocbj23 on topic who's running this?
Running the V and H on my 82 KZ. Had to straighten the brake pedal to run on top of the right footpeg.No frame work required.Not sure about the baffle.Running the street baffle in mine and it is very quiet.Did go to aluminum footpegs as the heat melted the rubber on the stockers.lol.bj
- Thank you received: 797
10 Feb 2011 13:47 #429824
by 531blackbanshee
Replied by 531blackbanshee on topic who's running this?
not sure about the pro pipe but some of the "sidewinder"type pipes hit the front fender/tire under hard braking if the front end has not been raked.that will lock the front tire and be potentially hazardous.
my buddy has a katana front end with the seventeen inch wheel and a v&h sidewinder(not pro) and it doesn't seem like it is going to contact.but it has not been rode yet either.
ymmv,
ymmv,
- andy9802gt
10 Feb 2011 13:59 #429827
by andy9802gt
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Replied by andy9802gt on topic who's running this?
bj, what's the part# on that pipe? Is it a sidewinder style or does it run under the bike?
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- dejavoodo41
- Thank you received: 14
10 Feb 2011 14:42 - 10 Feb 2011 15:31 #429839
by dejavoodo41
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
Replied by dejavoodo41 on topic who's running this?
I have the pro pipe on my 77 with a 19" front wheel and I don't have any clearance issues. I run rearsets so the the rear brake is a non issue.
www.bikebandit.com/vance-hines-drag-race...pes?mg=5016&t=1&td=1
Last edit: 10 Feb 2011 15:31 by dejavoodo41.
