'84 ZX1100 GPZ Engine Will Not Stay Running
- kevsell
- Motor Head
- Thank you received: 391
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Using the engine codes and just trying to think of the part that is causing the problem is frustrating as hell.
Use the manual, and check every electrical component independantly. Perform all the maintenence. Pull it, test it thoroughly, clean it properly, etc.
Its going to take a while, but have patience, it will be fine soon enough...
Best of luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Thank you received: 2098
If not already done, would inspect and probably remove this troublesome little inside filter, and replace it by installing a typical in-line strainer-type filter.
- Polar_Bus
- Thank you received: 7
I remember that thread, and you still show the voltage on the grey wire?
This fellow posted that he has changed the Computer, and still had the same code. But he so far has only posted the 1 time, still a problem, or fixed?
Hopefully you can fix yours, polar_bus.
I've tried swapping several major electrical components and after each swap, checking voltage at the temp sensor gray wire, and I keep showing about 1.7V (even with the key off. With key off there isn't supposed to be any voltage. I was hoping it was the main fuel pump relay, but swapped that too and still got voltage... it's just too dam cold right now to really dig into the electrics. Once it warms up a bit, i'll get back at it. I'm sure sooner or later i'll figure it out !
Bikes:
'84 GPz1100
'06 HD Fatboy
- kevsell
- Polar_Bus
Keep us posted. It aint that cold down here, so I'm hoping to make some headway tomorrow. I don't have a parts bike to swap pieces, but I've changed most of the major electronics already. I plan on going at it tomorrow until its fixed or until I collapse from exhaustion.
I am extremly fortunate in the sense that I have a complete spare set of compoenets. (I even had 2 complete DFI setups as well. So if my GPz starts giving me grief, I got it covered !
Bikes:
'84 GPz1100
'06 HD Fatboy
- kevsell
I once again measured the resistance of the sensor and found it to be about 2.4KOhms. I ohmed out the grey wire from the ECU connector to the sensor and found about 3kOhms. While I had the meter on both ends of the wire, I wiggled it around to see if there was an intermittent short or open. Sure enough I found that when I wiggled the wire near the fuse box, it would read open intermittently. Upon further investigation, I found a place jsut to the rear of the fuse box that the grey wire came out of the wiring bundle and a 30Ohm resistor was crimped inline on the wire. I thought that the problem was the cripms, but upon further investigation it seems that the wiring problem is between the resistor and the computer. I had to quit working on it because of rain. I am planning on replacing the section of wire between the computer and the resistor. I also have to wait until I can afford another battery for it because the one I have is deceased and they cost too much for me to just go out an buy one. I'll let you know more once I get it fixed and get a new battery in it.
- Motor Head
Get the new battery, a weak battery and fuel injection will be very bad for your old electronics. Check your charging system, there are many threads on this. I've done a couple myself, checking the Current flow in AMPs as well as voltage. Watch the voltage drop between the regulators brown wire and actual battery charging voltage. As the brown is the main ignition power as well as the Load Sense for the regulator. If there is a drop on the brown, the regulator will up the voltage to the battery possibly over charging/ boiling the battery, even e new one ruining it.
- kevsell
- Motor Head
I wish I could see the FSM for your year/ model to look at the wiring for the EFI, to see if that resistor is indeed mentioned.
- kevsell
