- Thank you received: 16
- KZ250LTD
- PLUMMEN
- Thank you received: 104
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- racer54
- Thank you received: 114
- PLUMMEN
stiff springs are harder to open which requires more power,not a really measurable amount i suppose.
the stiffer springs being harder to open would also mean they slam shut harder which is transfered to related valvetrain parts and seats.
putting stiff clutch springs in makes the clutch harder to pull in and is harder on related parts,what makes you think stiff valve springs react any differantly?
IM NO EXPERT,BUT I DO PLAY ONE ON THE INTERNET
- Motor Head
- Thank you received: 391
Are you always at the top of your Tach, or have a trans that jumps out of gear? The extra spring pressure would help in a over rev situation. Maybe get new stock springs installed at the correct height, or check those old ones and shim them back to the correct setting.
- larrycavan
- Visitor
I wouldn't worry for a nano second about increased oil temperatures from the valve springs.
As for valve seat issues with that setup....ain't going to happen I don't think most people really know just how freaking hard those KZ seats get after 30 years :laugh: Cut them sometime...you'll see what I'm talking about.
I go through carbide blades all the time installing over size valves. In fact I just ordered some more today.....
- KZ250LTD
- PLUMMEN
- testarossa
- Thank you received: 82
Heat treated and hammer forged at 9,000 rpm.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- kawsakiman
- Thank you received: 6
better then 30+ year old worn out springs.
been running them for 4 years on the 1100 with a stock motor with no problems.
- nads.com
- Thank you received: 20
A spring gives back the same amount of energy required to compress it.
So the ol carbide cutting tools are soft aay :woohoo: I'm a stone man myself, especially now. I suggest taking the carbide to a metallurgist for composition conformation. Then start the almighty lawsuit rolling. :woohoo: I never seen carbide give so easy but I have not messed with it much. I'm surprised that they would need replacing all the time.
