High Temp Exhaust Paint for KZ1100 Spectre??
- 2KZLTDs
29 Dec 2010 15:45 #419193
by 2KZLTDs
1976 KZ900B LTD (One runs, One rebuilding)
1980 KZ1300B (Next rebuild/may sell)
1983 KZ1100 Spectre (Running)
High Temp Exhaust Paint for KZ1100 Spectre?? was created by 2KZLTDs
Any good suggestions as pipes on bike are solid but need coating. Have heard good and bad on High temp powder coating (ceramic?) but not sure cost and if worth it?? Also some posts on low tech use of high temp grill paint but not sure this will hold up. What experiences people have here?
- RunDog
29 Dec 2010 15:59 #419196
by RunDog
Replied by RunDog on topic High Temp Exhaust Paint for KZ1100 Spectre??
Wrap em Looks cool Or I use grill paint Flat Black seems to hold up pretty good. All depends on what you want to spend. an exhaust can pretty much make or break the bike as far as looks go. The flat heat paint goes on really nice with no streaking if your good with a spray can:laugh:
- MFolks
- Thank you received: 540
29 Dec 2010 16:23 #419201
by MFolks
Replied by MFolks on topic High Temp Exhaust Paint for KZ1100 Spectre??
Surface preperation for a good exhaust paint job is a must.
If there is rust or old paint, find a sand/bead blaster to remove the old coatings before attemping to spray a new coat on.
- 2KZLTDs
29 Dec 2010 16:31 #419203
by 2KZLTDs
Replied by 2KZLTDs on topic High Temp Exhaust Paint for KZ1100 Spectre??
Thanks for input Rundog. I'm really tring to remain stock look so flat black that will hold up is the goal. Certainly flat black high temp paint from Auto store is the cheapest I suppose. Any brands suggested that have worked for people? Assume I should prime as well with high temp? What about ceramic powder coating does anybody have a guess on what this might cost and if it would be that much better?
- RunDog
29 Dec 2010 17:09 #419213
by RunDog
www.plasti-kote.com
Hi-temp paint. Do not by aluminum color. It does not look aluminum. Looks like shit. flat black covers the best You can get high gloss also. I do not know how much ceramic costs Every thing ive ever seen is really glossy. Unless you bike looks like new I would say it will stand out a bit much
- bountyhunter
- Thank you received: 337
29 Dec 2010 18:44 #419226
by bountyhunter
Replied by bountyhunter on topic High Temp Exhaust Paint for KZ1100 Spectre??
I used the VHT type black stuff for many years. Pipes must be clean, apply thin coat, cure paint with heat gun or paint will bubble off. The hi temp paint is OK but has to be redone every year or two.
- cdvanns
- Thank you received: 1
29 Dec 2010 22:32 #419251
by cdvanns
1978 KZ1000 A2
Replied by cdvanns on topic High Temp Exhaust Paint for KZ1100 Spectre??
Yep,I use VHT flat black and need to sand and repaint this spring after about a yr.
1978 KZ1000 A2
- Marneman
30 Dec 2010 07:56 #419289
by Marneman
77 KZ1000-A1 "Bushido" Project
82 KZ1000 LTD "Terri Lee"
You know what, I don't have a one to some other number of douche-bag scale. So.. Six!
Replied by Marneman on topic High Temp Exhaust Paint for KZ1100 Spectre??
Someone posted a link to this site on another thread
www.lo-ko.com/services.html
According to the author they do excellent work, and ceramic coat the inside and outside of the pipe for about $125 + shipping.
