- Thank you received: 6
Oil Cooler Line
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
- hocbj23
- Visitor
- stonemaster
- Visitor
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- MFolks
- Thank you received: 540
I took a Dremel tool with a cut off wheel and opened up the crimp end of the hose fittings. 3/8" I.D. hose should fit.
I've found that using the fuel injection hose clamps will make for a tight fit without the squeeze out through the standard "worm" hose clamps.
- keith1
- Thank you received: 2
i used -8 or -10(cant remember off hand) with hose clamps and chrome covers to my cooler.....for reference each "-" equals 1/16 inch....-8 would be 1/2 inch......i ran mine around the right hand side of motor and freed up space under the tank where the rubber lines had been.....
- Motor Head
- Thank you received: 391
Check this thread;
kzrider.com/index.php?option=com_kunena&...ew&catid=2&id=402420
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- hocbj23
- Visitor
Local Harbor Freight tool place had a box of viton O rings (assorted sizes) for 8 bucks recently.Might try them if the OEM stuff is hard to find.bjGood idea on the adapter block and lines. I will pull the adapter and find some new O rings. I have not removed the carbs and it is tight in there, but should be able to get it off and re-install it and the oil line.
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
