- Thank you received: 1
drilling exhaust flange holes to 8mm
- Ktm181
- Man made it, so Man can fix it
I have just fitted a different head to a Kz900 and found my exhaust flanges need to go up in stud hole size, has anyone experienced any problems drilling orignal KZ900 6mm flange holes up to 8mm to accept the Kz1000 sized exhaust studs? Bigger nuts of course but is there any other traps to be aware of?
As usual thankyou for your advice and MERRY CHRISTMAS! Hope you all have a safe and prosperous New Year riding.
Regards,
Kt
- MFolks
- Thank you received: 540
For an accurate sized hole, try to use a drill bushing that can be clamped in place. To remove any Burr, a countersink at low speed will cut it away.
- MFolks
- Ktm181
Kt
- Mcdroid
- Gone Kwackers
- Thank you received: 317
thanks for the speedy reply, i have a nice new 8mm drill bit,but no reamers, looks like drill will have to do, hate to modify original parts,might see if i can hold off and buy some alloy units from Z1E after the holidays.
Kt
Hello Kt:
I have done exactly what MFolks suggested (had a head with slightly bent exhaust studs and had to enlarge some flange holes). Go slow, lots of cutting oil, and it works well with no problems.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Jeff.Saunders
The genuine Kawasaki kz1000 flanges are step drilled. The front (visible) portion is 8.5mm, the rear is 10mm. This makes it easier to get over the studs on the later KZ1000 (which had beefier frame tubes).
www.z1enterprises.com
Z1 Ent on Facebook,
- dshelly
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- Ktm181
Regards,
Kt
- Ktm181
Kt
