- Thank you received: 1
no valve clearance
- Ktm181
- Man made it, so Man can fix it
04 Dec 2010 20:55 #415388
by Ktm181
no valve clearance was created by Ktm181
Hello Gents, hope you can answer a quick question for me, I am attempting valve clearance on a rebuilt head but have almost zero clearance (less than one thou)on 3 of the exhaust valves with a 2.0 shim, head is full reco with new valves,guides etc, I am wondering if it is possible to machine the underside of the bucket to creat more clearance?
Has Z1 Cammotion cams with shims top of bucket.Kz900,smog head,new cam bearings etc.I am guessing i have either a problem with the cam (doubtful)or valve stem heights incorrect.
any ideas? thanks heaps,
Kt
Kt
- bountyhunter
- Thank you received: 337
04 Dec 2010 23:53 #415405
by bountyhunter
Replied by bountyhunter on topic no valve clearance
I don't think it's safe to grind metal off the buckets. Normally, the ends of the valve stems have to be ground but there is only a little way that can be done safely until the keepers can pop off.
"I am guessing i have either a problem with the cam (doubtful)or valve stem heights incorrect."
I really doubt it's the cam. The valve stems should have been ground by the machinist who did the head to restore original valve end heights. Low clearance can also be caused by cutting the sets too deep.
- Ktm181
05 Dec 2010 15:41 #415504
by Ktm181
Replied by Ktm181 on topic no valve clearance
Thanks Bountyhunter, agree totally, "my" machinist is first rate, these things happen. Head coming back off!
Merry Christmas to all!
Kt
Kt
- lemo32
- The Price of Cool aint cheap
- Thank you received: 2
05 Dec 2010 17:10 #415530
by lemo32
1979 kz 1000 06 katana 750
Replied by lemo32 on topic no valve clearance
you can get thinner shims, that I'snt much clearance, not to sound stupid but you are checking em" lobe up right?
- TerryK
05 Dec 2010 17:16 #415531
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic no valve clearance
lemo32 wrote:
I believe 2mm is the thinnest shim available, hence his problem.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- lemo32
05 Dec 2010 17:42 #415536
by lemo32
with valve in head, stem height should be no more than 1.499 in. or 38.07 mm according to my manual, swap valves or grind a maximum of 0.012 in or 0.3mm of valve stem end
- APE Jay
- Banned
- Thank you received: 58
05 Dec 2010 22:53 #415589
by APE Jay
Replied by APE Jay on topic no valve clearance
Don't machine the bucket. You will have to tip the valves. There are gauges available for this.
racetoolz.com/
racetoolz.com/
- Ktm181
06 Dec 2010 15:21 #415694
by Ktm181
Thanks for all you replies and help guys, in process of removing my head, will have the valves machined. These things happen.
Jay, that link has some very nice additions for my home workshop!
Merry Christmas everyone, be safe and happy.
Kt:cheer:
Kt:cheer:
- toad
- Thank you received: 7
26 Dec 2010 04:10 #418630
by toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
Replied by toad on topic no valve clearance
I had the exact same problem, need to correct valve stem, I actually did machine a bucket before as a temporary fix and I had no problems but would not recommend it.Whatever was taken off the valve seat will affect stem height there after.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
