- Thank you received: 5
Cracked block near chain tensioner - KZ750 L3
- staniel
While I'm in there I'll re-check those bolts per your recommendation.
The guy I bought the engine off of said that not fully removing the cam chain tensioner before reinstalling it could strip those threads, so I'll be more careful next time.
1983 KZ750 L3 with 4-1 Kerker pipe and pods
1983 KZ750 L3 parts bike
- Thank you received: 2098
Would think any good volatile spray cleaner, such as brake cleaner or carb cleaner, would be okay for this purpose.
For example, failure to clear receiving cam bolt holes may exacerbate tendency to strip their threads when torquing the bolts.
- turboguzzi
- Thank you received: 72
just had a look at my cyl 750 block and the holes for the bolts form the head and from the chain tensioner do meet!
Really odd, looks like kawi engineers run out of space there as having the two holes connected like that certainly weakens the casting at that point, not a good engineering practice in my book, is it like that in the 1000's too?
it would be really important to have both bolts the right length, longer ones will simply touch each other and it would be easy to create a crack like yours even by just torquing them to spec, its like driving a wedge!
Check the bolts you took out of there, wouldnt be surprised if the threads are marked from rubbing steel against steel.
Good to know....
- staniel
The OEM bolts are threaded at the bottom and tapered in along the middle. I'll guess that's to take up the last few millimeters of tensioner bolt, and since I used a regular fully-threaded bolt for the head, the top tensioner bolt pressed right up on those threads. Good thing stainless is hard, or I'd have to guess I'd smashed the threads on the head bolt.
Fortunately I saved the original bolt that didn't shatter on me, so I'll use that for the rebuild when good weather comes.
- TerryK
- Thank you received: 3
I wish I didn't have to get a new set of gaskets and do the whole razor-cleaning of the surfaces all over again. That was a real pain.
Buy a good quality liquid gasket remover and let it work on the gaskets before you try to scrape them off. It will be TONS easier!
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- turboguzzi
rebuilds are done in bad weather, good weather is for riding
- staniel
This is true for those fortunate enough to have a garage. I live in Seattle with no workspace. Please don't make fun.. the situation is sad enoughrebuilds are done in bad weather, good weather is for riding
TerryK, I used liquid gasket remover the last time I did it and it was still an epic PITA. Maybe it'll be easier since the gaskets are 5 months old instead of 27 years. I guess it's a fair assumption that I'll need all new gaskets for this project? Can't reuse a head gasket if I used Permatex?
I'll surely post updates when I do all the work again.
Thank you all for the help. If any of you lives in Seattle and has a place to work, please let me know!
- turboguzzi
who told you to do so?
- staniel
- TerryK
If you peel most of the gaskets off before you put on the gasket remover it shouldn't be much of a problem...however I don't think it will touch permatex. A little sealer around the dowels is fine, as long as its a LITTLE bit and not a blob. If you have sealer on it all I can say is: happy scraping!!
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- turboguzzi
Dangit. My Clymer manual said to put some around the two dowel bolts! I used the black stuff, though, so maybe it'll peel off with a wet rag...
as long you didnt smear ALL OVER the gasket then your ok
