- Thank you received: 5
Cracked block near chain tensioner - KZ750 L3
- larrycavan
- Visitor
- staniel
So I can take the sleeves out with an oven but not put them back in? Why wouldn't they slide in as easily as they came out?
(Side question, since I'm gonna visit a stranger soon and buy parts off his 1981 KZ750.. will that bike have the same igniter and ignition coils?)
1983 KZ750 L3 with 4-1 Kerker pipe and pods
1983 KZ750 L3 parts bike
- Thank you received: 2098
Per kawasaki.com -- the igniters have different part numbers....gonna visit a stranger soon and buy parts off his 1981 KZ750.. will that bike have the same igniter and ignition coils?)
But ignition coils (each side having different number) seem the same.
If needed, here's some help about using kawasaki.com
Click > kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
- staniel
I see now, the igniters are different. Still, if the price is right, I'll buy it and hope. I found one online for $85 as well.
So, the current plan is to get a new block and swap sleeves. Regarding tribology, how important is it to maintain the angle? If the 60° mark on a piston ring seats itself to the 60° mark on the sleeve, what happens if the ring rotates 15° during the reinstallation? Do you have to break it in again?
Could the crack have been caused by a loose head mounting bolt? I did not retighten them after heating and cooling the engine...
Would meanwhile consider Larry's suggestion to Tap the top bolt hole to 1/4", or next slightly larger size of whatever thread that would enable a snug torque (or perhaps heli-coil or threadsert). And ride. Keeping a close eye on the situation....have to replace the block, which is hilarious. At what point do you simply replace the whole engine with one that works?
Am perhaps overlooking some catastrophic potential, and must defer to Larry and others for more competent advice about risk of causing additional engine damage or bodily injury.
Hoping for more input as to feasibility of the less expensive alternative.
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
When my 650 needed the head replaced (I buggered the origional head removing it) I just used the top end from a donner motor that was disassembled but had 10K on it (20K miles less than my motor). I swapped the blocks and pistons without knowing which piston came from wich hole. The motor has 125-135 psi in all holes my mechanic said it held air well in the leakdown test. Either I got very lucky, or it just isn't as critical as people make it out to be.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- kawsakiman
- Thank you received: 6
- seanbarney41
- '79 kz1000 LTD '75 Honda CB750
- Thank you received: 23
- staniel
- TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- larrycavan
- Visitor
This may or may not take care of the situation. No guarantee but it's an option that doesn't require a tear down.
As TerryK suggested, New bolts were possibly too long, bottomed out and pushed that piece out....I used two new bolts in tightening the head on and these bolts come straight through to that point. I bought stainless steel ones and ground them down to size....
Wouldn't hurt to remove the bolts and double-check for this possibility.
