rear wheel spins while in neutral?
12 Nov 2010 19:19 #412459 by John T
rear wheel spins while in neutral? was created by John T
84 GPZ1100
while on the center stand, in neutral... the rear wheel spins.. grab it with your hand and it stops...
let go, it starts again..
on the road, the clutch pulls fine, no slipping...
over the years, I have noticed other bikes doing this.. slightly.
but nothing ever this bad... the wheel is spinning quite fast....
thoughts?
True Wisdom Only Comes From Pain.
12 Nov 2010 19:21 #412460 by Mark Wing
Replied by Mark Wing on topic rear wheel spins while in neutral?
Sounds normal to me.
Mark
Yorba Linda Cal.
12 Nov 2010 19:21 - 12 Nov 2010 19:22 #412461 by bountyhunter
Replied by bountyhunter on topic rear wheel spins while in neutral?
Normal friction. If you can hold it with your hand, no worries. A thinner oil might make it do it less?
Last edit: 12 Nov 2010 19:22 by bountyhunter.
12 Nov 2010 19:32 #412465 by John T
Replied by John T on topic rear wheel spins while in neutral?
cool.
thanks...
like i said, everything else is fine... pulls good on the road. just looks strange on the centerstand the other day when I had it running...
12 Nov 2010 19:35 #412467 by MFolks
Replied by MFolks on topic rear wheel spins while in neutral?
Just a normal condition due to oil being flung from the clutch plates like a automatic transmission does in a car.
12 Nov 2010 20:51 #412478 by TerryK
Replied by TerryK on topic rear wheel spins while in neutral?
Normal.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
12 Nov 2010 21:27 #412482 by Injected
12 Nov 2010 22:19 - 12 Nov 2010 22:20 #412483 by Patton
Replied by Patton on topic rear wheel spins while in neutral?
Injected wrote:
www.youtube.com/user/dakegmeister#p/a/u/2/kXZ3ASD9XTo
revving motor in neutral
Excellent video answer to the question. :cheer:
Kept waiting on the gent to press the brake pedal, but he never did. :lol:
I would've had to do so on general principle. :laugh:
Good Fortune! :)
Last edit: 12 Nov 2010 22:20 by Patton.
13 Nov 2010 08:02 #412509 by RonKZ650
Replied by RonKZ650 on topic rear wheel spins while in neutral?
Actually it's not the clutch that causes the wheel to spin in neutral, it's the transmission gears. If you look at the transmission while in neutral there are no dogs engaged, but some gears are spinning always when the engine is running, some are splined to the output shaft. These gears are side by side with only a few thousands of an inch separating them so naturally when one spins the others try to spin with them without load, so once the wheel is on the ground it is no longer noticable. There is potential for this problem to actually be a problem though. I bought a KZ650 and the engine really pulled in neutral badly, enough that it made it very hard to enjoy riding. All the guys kept saying "adjust your clutch". If you think about it what does the clutch do in neutral? Absolutely nothing as the plates are completely locked with the lever out and the engine should not have noticable drive in neutral. What it ended up being was I had a defective gear that had a pressed in center that was as far as I can tell never fully centered on the gear which basically made the gear too wide for the space it occupied on the shaft so it was supposed to be an idler but was binding badly.
  • trianglelaguna
13 Nov 2010 12:24 #412543 by trianglelaguna
Replied by trianglelaguna on topic rear wheel spins while in neutral?
it is not normally a problem...i guess Rons makes sense that in rare cases it can be indicative of coming or existing tight clearances ........
i know this sounds self explanatory but....it can however be highly dangerous as owners use this free wheeling activity to clean the rear wheel.......i myself have almost lost a finger nail or had a rag suck my fingers into the rear sprocket...........trying to clean rims while the bike is running in neutral works until the first time where like me you lay the meat of a finger tip open...sounds...dumb.......many have this lesson down though,.....
great for checking run out
great for lubing the chain
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
13 Nov 2010 12:41 #412545 by JMKZHI
Replied by JMKZHI on topic rear wheel spins while in neutral?
Someone over at the Kawasakimotorcycle.org site reported that his nephew lopped off a finger while lubing or cleaning the chain on his sportbike while the engine was running. I wonder how often that happens? One or two folks chimed in, saying that it's apparently a normal practice to lubricate the chain n stuff while the engine is running. I say... nuts.
13 Nov 2010 12:58 #412547 by Patton
Reminds of the mechanic's long hair getting caught in the fan belt. :pinch:
