- Thank you received: 2
rear wheel spins while in neutral?
- John T
while on the center stand, in neutral... the rear wheel spins.. grab it with your hand and it stops...
let go, it starts again..
on the road, the clutch pulls fine, no slipping...
over the years, I have noticed other bikes doing this.. slightly.
but nothing ever this bad... the wheel is spinning quite fast....
thoughts?
True Wisdom Only Comes From Pain.
- Mark Wing
- Thank you received: 22
Mark
Yorba Linda Cal.
- bountyhunter
- Thank you received: 337
- John T
thanks...
like i said, everything else is fine... pulls good on the road. just looks strange on the centerstand the other day when I had it running...
- MFolks
- Thank you received: 540
- TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- Injected
- Thank you received: 543
- Thank you received: 2098
Excellent video answer to the question.www.youtube.com/user/dakegmeister#p/a/u/2/kXZ3ASD9XTo
revving motor in neutral
Kept waiting on the gent to press the brake pedal, but he never did. :lol:
I would've had to do so on general principle. :laugh:
- RonKZ650
- Thank you received: 240
- trianglelaguna
- Thank you received: 235
i know this sounds self explanatory but....it can however be highly dangerous as owners use this free wheeling activity to clean the rear wheel.......i myself have almost lost a finger nail or had a rag suck my fingers into the rear sprocket...........trying to clean rims while the bike is running in neutral works until the first time where like me you lay the meat of a finger tip open...sounds...dumb.......many have this lesson down though,.....
great for checking run out
great for lubing the chain
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- JMKZHI
- Thank you received: 48
