Porting for a turbo
- School Teacher
Porting for a turbo
12 Nov 2010 18:15 - 12 Nov 2010 18:18
well i have these parts
A welded j crank with the 16 tooth center pin
A j head
a zn1100 head
a 1200j/gpz kit wiseco 10.25 kit(new)
I have a back cut tranny and a welded basket/lockup clutch
i was thinking selling the kit, and j head and running a zn head with 84gpz pistons(buying one in the 1200 sizeand correct compression) and turboing that sucker.
should i use the gpz head or the j head and what kind of porting on the heads should be done?
street strip bike (not a wheely bar bike though)
A j head
a zn1100 head
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
1980 kz1000G1
Last edit: 12 Nov 2010 18:18 by School Teacher.
- TerryK
Re: Porting for a turbo
12 Nov 2010 21:03
Not sure about the turbo combo, but might be interested in the "kit".
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- zed1015
13 Nov 2010 10:51
Forced induction!
Porting not really needed.
- larrycavan
13 Nov 2010 18:49 - 13 Nov 2010 19:17
Porting can still provide benefits to a turbo motor. Turbos increase density not flow. That doesn't mean that there are times when porting a turbo motor shows a big difference at the drag strip.
I've seen times where guys have installed turbo cams and not seen a difference either.
It's the combination and how it' setup for the intended use that matters most
If you're referring to the 84 - 85 shaft drive 1100 head, that is the same as the 83 - 85 GPz head except the temp sensor boss is not tapped.
A standard J head is different. Hemi chamber w/ smaller valves. 37/32
Any of those 3 heads with a turbo will make for a quick ride.
Last edit: 13 Nov 2010 19:17 by larrycavan.
- PLUMMEN
13 Nov 2010 20:03
on a kz head go with 1 size over exhuast valve and concentrate on cleaning up exhuast ports/bowls,turbo will deal with the intake side
- larrycavan
15 Nov 2010 14:25
A 1mm over exhaust valve won't do much if the port's not setup for it
There's a lot more to installing larger valves than guys think....
Larry C
Larry C
- School Teacher
15 Nov 2010 14:43
So if i went with a bathtub head the head shouldn't need porting, for street strip bike is what i am taking away from this.(maybe just a clean up on the intake/exhaust?)
1980 kz1000G1
1980 kz1000G1
- larrycavan
15 Nov 2010 14:57
IF using 83 GPz style head with turbo...
Valves are plenty big enough for 1200cc.
Punch the throats out to 90% on both sides. Clean up the runners. Bolt on the turbo. Crank 14.7lbs to it and you effectively have a 2400cc motor on full boost.... That should put lead in your pencil :laugh:
- School Teacher
15 Nov 2010 15:03 - 15 Nov 2010 15:04
Sounds good to me
1980 kz1000G1
1980 kz1000G1
Last edit: 15 Nov 2010 15:04 by School Teacher.
