My Kz 1000ltd lost compression in the 2 middle cyl
- kz1000ltdrider
1977 KZ1000 LTD
- Thank you received: 2098
- kz1000ltdrider
1977 KZ1000 LTD
- JR
- Thank you received: 448
Hard to imagine both 2 and 3 lost compression at same time.
Possible though
The one ignition coil fire 2 and 3
- gane
- Thank you received: 1
[img][/img] 1977 KZ1000A1
- keith1
Mike, I'd pull #'s 2 & 3 plugs & perform a leakdown. A blown head gasket between 2 & 3 would cause your' prob. & not be apparent from the outside. luck G
i m with gane.....could have let go and is blowing compression down the cam chain tunnel.....see if you have a lot of oil where the breather ends up...should be near the air filter on a stock bike.....its a possibility....
...took the valve cover off and by looking at it they seem about the same. when I turn it over it looks like its working well ports were all opening and closing in all 4 cylider but I will check it any how....
Will need a thickness gauge.
Correct valve gap is 0.05 mm ~ 0.10 mm.
It's okay to go slightly wider, but wouldn't exceed 0.15 mm.
Need any help with the valve gap checking procedure?
Btw, what year bike?
- kz1000ltdrider
thanks for all the help guys and gals Im open for all ideas on this one it all helps. I am happy to find this site its lots of help.
1977 KZ1000 LTD
- kz1000ltdrider
1977 KZ1000 LTD
- keith1
sorry to hear and good luck...all is not lost...its fixable....
Click these links.
www.z1enterprises.com/detail.aspx?ID=2717
www.z1enterprises.com/detail.aspx?ID=462
www.z1enterprises.com/detail.aspx?ID=456
www.z1enterprises.com/detail.aspx?ID=470
And much much more.
