KZ750 twin exhaust cam for intake for more power?
- dnz
- Becker
- The Doctor Will Rise Again
- Thank you received: 1
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
- bountyhunter
- Thank you received: 337
If there was a cheap and/or easy way to jack up the power, kawi would certainly have done it. HP ratings on bikes is a major selling point.Will this work to make more power? Would be a cheap source of extra power.
In general, bike engines are tweaked up so fine in matching the intake, cam, exhaust characteristics for maximum power that screwing around with any one will almost certainly make it worse.
You have to change them as a set and you really have to know what you are doing to get it right.
- Headly
73z1a fireblade front&rear,75z1b,74z1a,05 husky 510,xl567.
Ask the toe cutter,he knows who i am!
- 893cv
- Thank you received: 15
1980 kz1000 LTD
1978 Z1R
- dnz
I'm sorry I'm not one hundred percent sure what you are talking about. Flip flopping the cams or installing a separate exhaust cam to put in as the intake cam. Why do you think this will help horsepower. I'm just curious.
I had read that some engines can gain HP by doing this, like the Busa's. I should've said intake not exhaust. The reason is because the intakes valves are larger than exhaust.
- zed1015
- Thank you received: 1554
Fitting an inlet cam on the exhaust side is an age old dodge to aid scavenging and get a better cylinder intake fill at higher revs.
Ask anyone with an old triumph bonny etc, This is/was a common tuning mod when over the counter aftermarket cams etc were not available.
Start off with the std lobe centers and work from there.
You'll be very unlucky to get an adverse effect, You should gain 'slightly' more top end power and a willingness for the engine to rev out more cleanly.
A small up jet may be needed and a free flowing air filter would help.
Of course it may make no difference at all depending on how much difference there is between inlet and exhaust cams but you'll never know till you try it
- Nebr_Rex
- Thank you received: 300
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- 893cv
1980 kz1000 LTD
1978 Z1R
- bountyhunter
On mine, the exhaust cam has a tach drive on one end.If you install the exhaust cam on the intake side of the head, it will not turn.
- Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- Headly
