oil cooler
  • 9am53
  • homebrew, and some bbq
28 Oct 2010 11:51 #409611 by 9am53
Replied by 9am53 on topic oil cooler
Old Man Rock wrote:
BTW... Those OLDkaw setup images..... Egad :S ...
lol, I don't know what's worse, the setup, or the orange gasket goo everywhere!
  • DoubleDub
  • Visitor
28 Oct 2010 12:32 #409615 by DoubleDub
Replied by DoubleDub on topic oil cooler
Old Man Rock wrote:
Installed images...
Hey Dave - any chance you can give us a shot of the connections on the cases?
28 Oct 2010 19:03 - 28 Oct 2010 19:07 #409680 by Old Man Rock
Replied by Old Man Rock on topic oil cooler
DD... Let me know if you need some different images and I'll take some more if required... Fairly straight forward on the configurations....
NOTE: And yes before one of you wise asses pick up on it, I realize the inner coupler has oil streaks... :angry: The Oil Sending unit was loose at first... All better now.... :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 28 Oct 2010 19:07 by Old Man Rock.
28 Oct 2010 19:05 #409682 by Old Man Rock
Another....
BTW, picked up the braided stainless 3/8" hose (10') with 4 couplers for $50 at local HD shop... Yeah I know, go figure.... :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
28 Oct 2010 19:08 #409684 by keith1
Replied by keith1 on topic oil cooler
dave,
same ones i used.....more for dress-up than anything as far as the clamp covers go......good looking set-up.....i got my shit from jeg's......
28 Oct 2010 19:19 #409685 by loudhvx
Replied by loudhvx on topic oil cooler
CoreyClough wrote:
Like that of a radiator, the oil needs to flow slow enough through the cooler to actually cool the fluid...
Actually, that's a misconception. The faster the liquid flows through the cooler, the hotter the cooler will be so the faster it will give off heat to the air coming through.
It's the temperature differential that matters. Heat transfer is fastest when the hot item (aluminum or brass fins) is much hotter than the cool item (incoming air).
This misconception comes from using a restrictor in the coolant line in old cars. In some old cars, to get more cooling, you put a restrictor into the cooling system. What people didn't realize is that the restrictor was being placed into a BYPASS line. This forced more coolant into the radiator which cooled the engine faster by pushing more coolant through the radiator faster.
  • DoubleDub
  • Visitor
28 Oct 2010 20:05 #409691 by DoubleDub
So I looked at my 900 and I don't see quite the same connectors on the pressure switch - it looks like there is only a bolt for the pressurized side to be connected as seen here in attached image from Kawasaki part diagram.
Are those aftermarket adapters or from another model bike?
28 Oct 2010 23:22 - 28 Oct 2010 23:24 #409707 by Old Man Rock
Probably I'm mistaken but this seemed OEM due to kawi oil cooler stamping, so I assumed OEM on the crancase mounts...
Plus the outer mount has a rounded top (casted) so lead me to believe the same...
Salvage yard, old rusted frame with sun baked engine etc...
Didn't catch the year or model # at the time... :blush:
Similar to these found at American classix.... $85 :pinch:
americanclassix.com/kawa_improvements.html
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 28 Oct 2010 23:24 by Old Man Rock.
  • DoubleDub
  • Visitor
29 Oct 2010 05:05 #409716 by DoubleDub
Ouch...spendy. :unsure: Thanks!
29 Oct 2010 08:55 - 29 Oct 2010 08:57 #409749 by Patton
Replied by Patton on topic oil cooler
Old Man Rock wrote:
No need to say any more....
Okay, but what happened to the earlier plan? :laugh:
[Click on image to see OMR change the cover shot on his new oil cooler tutorial.]
Good Fortune! :)
Last edit: 29 Oct 2010 08:57 by Patton.
29 Oct 2010 08:57 #409751 by Polar_Bus
Replied by Polar_Bus on topic oil cooler
If anyone needs, I have a complete GPz1100 OEM oil cooler setup.
Bikes:
'84 GPz1100
'06 HD Fatboy
30 Oct 2010 19:51 #410017 by jab
Replied by jab on topic oil cooler
Hey Old man rock, your bike is totally awesome !! I like the cooler set up-. I just purchased the same professionally machined cooler ports from "American Classic". Did they come with gaskets ? I was looking at your chain gaurd, was the ordered from AC too ?
thanks - JAB
