oil cooler
25 Oct 2010 16:50 #409025 by jab
oil cooler was created by jab
Hey all. Many thanks to those who helped with the previous posts on cam degree-ing. the bike is running awesome ! Looking at an oil cooler based on the engine mod's that I've done. Ebay has a model 600 cooler with built-in thermostat advertised for Harley's. Can't help but think its fine for all bikes, but wanted forum feedback. Any think to worry about with the internal thermo ? I definitely want a temp control, so this would be a very clean installation. Coolers from JEG's or Summit are much cheaper, but then you have to plumb in the thermostat. Into appreciated. thanks Jeff B
25 Oct 2010 16:51 #409026 by jab
Replied by jab on topic oil cooler
little more info. Sorry in a hurry. The cooler is a Lockhart model 600.
25 Oct 2010 16:53 #409027 by Powerstroke_fan
Replied by Powerstroke_fan on topic oil cooler
i am in the process of making one here is a link to the best site ive found about this
www.oldkawman.com/okndoil.html
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
25 Oct 2010 16:54 #409028 by Powerstroke_fan
and heres the cooler iam going to be running.
trucool.carshopinc.com/product_info.php/products_id/55218/B7B
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
25 Oct 2010 16:57 #409029 by Powerstroke_fan
and you can buy the lines and fitting off summit relativly cheap and you still gotta get a oil cooler adapter either way and i wouldnt buy a cooler if its used EVER!!! one simple reason if the motor it came off of had problems and got metal shavingings in the cooler then you put it on your bike where do you think the shavings will go? and you cant completely clean all shavings out either
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
25 Oct 2010 17:30 #409039 by jab
Hey, powerstroke, thanks for the reply. You're absolutely corerct about the "used" oil cooler thing. Work in contruction equipment hydraulics, and I know for a fact that if something in the system lets go, the cooler is a collection point and you can NEVER get them clean. This cooler is brand new. I plan on getting the "engineered" motor fittngs from an after-market suppler. Also, your right that oldmankaw has an aweswome website !! Your bike looks great. Good luck with it.
  • CoreyClough
  • GPz550 Addiction
28 Oct 2010 04:54 #409554 by CoreyClough
Replied by CoreyClough on topic oil cooler
You can have a radiator shop boil out the used cooler, and they can also flow check it for you, to see if there are any restrictions inside.
Like that of a radiator, the oil needs to flow slow enough through the cooler to actually cool the fluid, so a thermostat or an in-line restrictor will do this. Most fluid thermostats I've had fail, end up sticking in the closed position. Just make sure you're getting air to the cooler itself.
'85 GPz550(ZX550-A2)
28 Oct 2010 05:13 #409557 by Old Man Rock
Replied by Old Man Rock on topic oil cooler
No need to say any more... Earls curved 10-Row cooler...;)
goodies-speedshop.com/p-1381-search-by-part-number.html
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
28 Oct 2010 05:15 #409558 by Old Man Rock
Installed images...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
28 Oct 2010 05:19 #409559 by Old Man Rock
Due to the OEM cooler mounts I found at the local salvage yard ($5 :cheer: ) had to go off the left side of the engine.... No big deal...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
28 Oct 2010 05:23 #409562 by Old Man Rock
Fab yourself up some brackets and secure to side reflector mounting holes....
Pretty much everything required... Now if you require, you can install a thermo switch, Jeggs has them for around $69-$80 for manual/auto switching....
BTW... Those OLDkaw setup images..... Egad :S ...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • kz1k
  • You Cant Fix Stupid!
28 Oct 2010 08:25 #409580 by kz1k
Replied by kz1k on topic oil cooler
great thread!!!!!
1978 KZ1000A2
