1982 KZ1000 K2*********NO START CONDITION*********
- bowtie6686
- good, fast, cheap: choose two of the following
-new valve shims
-new battery
-new pilot and main jets(40/140-with pods and 4 into 1 exhaust)
-new intake boots
-new battery cables
I have also checked and cleaned all electrical connections, coils check out ok and are receiving a proper 12 volts, compression check revealed 125-145psi on all cylinders. I have had the bike running only a handful of times but the battery usually gives out before I can get it started. One concern I have is the motor isn't turning over quite as much as I would like while starting. If I hold the starter switch the motor turns over about a quarter of a revolution, pauses, another quarter, pauses and continues in this manner...eventually running the battery down. At first I thought the starter clutch was slipping but there is an excessively loud whine perhaps coming from the starter itself, making me think the starter is in need of a rebuild. Could this be what's making it hard to start? Are the pods the problem? Perhaps I need rebuild kits for the carbs? I am running out of ideas and am desperate for some guidance.....PLEASE HELP?!?!
- MFolks
- Thank you received: 540
Download this shop manual:
www.kawiworld.com/index.php?option=com_c...icle&id=77&Itemid=99
Starter Motor Rebuild Kits
www.mawonline.com/newsite/rick_s_motorsp...-starter_brushes.htm
www.cyclewareables.com/pages/street_star...kits/startmtrkit.htm (not sure if website is viable)
www.psep.biz/store/mitsuba_starter_motors_page_2.htm
- bowtie6686
- MFolks
Having an alternator gasket on hand is a good idea as they sometimes tear on removal. I use a sharpened piece of lexan or Plexiglass to scrape any old gasket left on the engine or covers as they will not damage the soft aluminum pieces.
- 9am53
- homebrew, and some bbq
- Thank you received: 3
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- 9am53
If there are pods on the bike but the jetting is stock you will likely have to run with the choke all the way out to keep it going. What are the jet sizes?
EDIT: I see you did use 40/140 jets, what are your mixture screws at? After rejetting I have mine at (I think) 3.75 turns (I think....)
'84 GPz900r
'71 CB350
- bowtie6686
- MFolks
Ensure the connections of the jump cables are correct:
RED to RED (+ to +)
BLACK to BLACK (- to -)
If the bike cranks good and starts, think about using larger battery cables and the ones going to the starter motor. 6 gauge welding cable comes in two colors(Black and Red), take your old cables to the welding supply stores or have careful measurments for new cables.
If the welding store can't put new terminal ends on the cables, try the battery stores as some have dedicated machines to squeeze/swage the terminal ends.
- bowtie6686
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Starter can be easily removed from bike and then tested at a electrical motor rebuilder with the correct equipment.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Thank you received: 2098
Use a known good battery/car battery for testing....
For that one person on the planet that maybe doesn't know ---
If jumping from a battery in another vehicle, be sure the vehicle's engine is NOT running.
- MFolks
