#1 cylinder not getting hot
26 Oct 2010 07:54 - 26 Oct 2010 08:00 #409146 by 81kzjim
Replied by 81kzjim on topic #1 cylinder not getting hot
thanx ed. i do have large screwdriver that fit very nice. i did put lots of pressure afraid of stripping screw heads.
off to work,
jim.
1981 650 csr
Last edit: 26 Oct 2010 08:00 by 81kzjim.
26 Oct 2010 08:36 - 26 Oct 2010 09:22 #409155 by Patton
Replied by Patton on topic #1 cylinder not getting hot
Besides maintaining firm fit and contact with the screw head, the impact driver adds an initial jarring shock (that's missing when applying torque with a normal screw driver) which seems to sometimes help overcome and break past the initial resistance of tight threads.
My specially is over-doing with air-wrench Phillips head bit and manage to scour out a screw head while it keeps whirling away after already tight. :laugh: :laugh: :laugh:
And only then think to reduce the torque setting. :pinch: :laugh: :laugh:
Good Fortune! :)
Last edit: 26 Oct 2010 09:22 by Patton.
26 Oct 2010 08:45 #409157 by 650ed
Replied by 650ed on topic #1 cylinder not getting hot
81kzjim wrote: "i do have large screwdriver that fit very nice"
I would then suggest putting some Kriol on the screws a couple times a day for 2 days. If that and the large screwdriver don't work I would run the engine with the petcock off until the carbs run out of fuel and then carefully remove the bowls (they will still have some fuel in them). It may then be easier to apply LOTS of force to the screws when the bowls are on your bench or use the impact driver judiciously without jarring the carbs and carb holders. Ed
26 Oct 2010 09:12 #409161 by JMKZHI
Replied by JMKZHI on topic #1 cylinder not getting hot
Note: wd40 isn't a very good penetrant.
If Kroil isn't readily available, LiquidWrench Penetrating Spray Lubricant is a good & cheap alternative that can be found at a lot of places - it's what i use (I hate the wd).
As for doing the carbs, be sure to check the functionality of the accelerator pump. When vigorously actuating the throttle pulley, fuel should squirt out the pump nozzles that project into the carb bore - the fuel should shoot straight back without hitting the sides.
26 Oct 2010 09:38 #409167 by kawsakiman
Replied by kawsakiman on topic #1 cylinder not getting hot
and remember just because you have gas going to the carbs that don't mean you have gas going through the carbs.
26 Oct 2010 10:18 #409172 by 81kzjim
ok update on screws, #2#3 now loose #4 not yet. waste of time on screws, carbs coming off to redo anyway. going to look for carb kits on line, thanx again for info everyone.
jim.
1981 650 csr
26 Oct 2010 14:02 - 26 Oct 2010 14:06 #409201 by Patton
jim.
Thanks for the report. :cheer:
Hoping for success with #4.
For 1981 KZ650-H1 (CSR), Kawasaki.com shows drain screw Part No. 92066-1064 still active and last used on 2005 KZ1000-P24 (Police 1000). Should be available through Kawasaki dealer.
If needed, could likely also be obtained through Z1E:
Parts: Click > www.z1enterprises.com/catalog.aspx?pid=KZ650-H1-1981
Contact: Click > www.z1enterprises.com/contactinfo.aspx
Am unfamilar with any kit for this carb that includes drain screw.
Good Fortune! :)
Last edit: 26 Oct 2010 14:06 by Patton.
27 Oct 2010 15:47 #409467 by 81kzjim
hey patton thanx for all the help with parts and ideas. will post progress soon.
jim.
1981 650 csr
28 Oct 2010 17:49 - 28 Oct 2010 17:51 #409659 by 81kzjim
I have a wonderful son that got a pic on my phone to the computer. it is our old girl. it looked much worse, but we got in in great shape to us. were gonna work more on it over the weekend, i will post at a later date. by the way as you can see the old girl needs a new seat.any ideas or info on what and or how to get one??
- jim :laugh: :lol: B)
1981 650 csr
Last edit: 28 Oct 2010 17:51 by 81kzjim.
28 Oct 2010 18:33 #409673 by Patton
Here's a way to add bike info to signature, such as "1981 KZ650 CSR," plus additional info as desired.
Click here > kzrider.com/index.php?option=com_kunena&...d=8&id=382004#382317
Good Fortune! :)
29 Oct 2010 08:08 #409743 by JMKZHI
If the seat cover is torn but the foam is fine you can recover it.
Here's a seat recover topic w pics & links - it's the same bike as yours.... Seat cover stuff
It's a Travelcade cover, and except for the flat black color it's virtually a perfect match as stock.
