#1 cylinder not getting hot
23 Oct 2010 16:16 - 22 Jan 2013 01:34 #408594 by H1Vindicator
Replied by H1Vindicator on topic #1 cylinder not getting hot
Last edit: 22 Jan 2013 01:34 by H1Vindicator.
23 Oct 2010 18:15 - 23 Oct 2010 18:24 #408620 by TerryK
Replied by TerryK on topic #1 cylinder not getting hot
wargoth wrote:
Once again, lets jump to conclusions and look at the hard stuff first...
I didn't see anyone jump to conclusions, I saw a few well versed people who know a bit of what they speak, that actually READ what the original posted said. It would be obvious to anyone with any mechanical skills or half a brain that if the plug is dry there is no fuel. Also, the likelihood of a plug wire going bad is very slim at best so the obvious easy answer is fuel.
How would carbs out of sync cause the cylinder to not get fuel? How would valve lash cause the cylinder to not get fuel?
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Last edit: 23 Oct 2010 18:24 by TerryK.
23 Oct 2010 19:19 #408632 by Patton
Replied by Patton on topic #1 cylinder not getting hot
A non-sealing exhaust valve, for example, may impair the cylinder's ability to suck in fuel mixture from the carb during the intake stroke.
While not the most likely culprit in this instance, would verify acceptable compression and valve clearances being within specs before ruling out everything except a carb issue.
This also presupposes a good properly timed spark, which imo should further be assured before addressing the carb.
Even perfect carbs can't compensate for a weak or improperly timed spark, or inadequate compression due to incorrect valve clearances or whatever reason.
All that said, imo the dry plug in this case most likely results from a carb issue (related to fuel supply and/or pilot circuit).
Good Fortune! :)
25 Oct 2010 16:38 #409021 by 81kzjim
Replied by 81kzjim on topic #1 cylinder not getting hot
well, went ahead and checked for gas getting to carbs, #1 carb plenty of gas out of float bowl drain, but very dirty. looks like inside of gas tank needs good cleaning along with carbs. could not get drain screws to turn on #2/#3/#4 any ideas how to loosen drain screws? sprayed with wd40 will try again tomorrow. also what will clean inside of gas tank? somebody said to try little bit of gas with small washers/nuts and shake for a bit then drain. flush with clean gas. will order carb rebuild kits as well. anybody ever buy parts from BABBITTS any good?
thanx jim
1981 650 csr
25 Oct 2010 17:27 - 25 Oct 2010 17:28 #409037 by Patton
thanx jim
Impact driver is handy tool for loosening stubborn fasteners, etc.
Fuel tank cleaning tutorial,
Click > kzrider.com/index.php?option=com_content...view&id=22&Itemid=11
Best parts source,
Click > www.z1enterprises.com/
Good Fortune! :)
Last edit: 25 Oct 2010 17:28 by Patton.
25 Oct 2010 19:39 #409068 by 650ed
Replied by 650ed on topic #1 cylinder not getting hot
81kzjim wrote:
"... also what will clean inside of gas tank? somebody said to try little bit of gas with small washers/nuts and shake for a bit then drain. flush with clean gas..."
Rust Removal
  • newOld_kz1000
  • FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
25 Oct 2010 20:45 #409085 by newOld_kz1000
Replied by newOld_kz1000 on topic #1 cylinder not getting hot
Good idea to install in-line fuel filter right after a carb clean, regardless of the state of the gas tank. They are inexpensive and with no moving parts and ability to see the gas being present, they are a win -- saves you the trouble of having to yank and re-clean a bank of carbs that you had just finished cleaning only to have that cleaning session spoiled by gas tank junk.
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
26 Oct 2010 04:38 #409123 by JMKZHI
Replied by JMKZHI on topic #1 cylinder not getting hot
81kzjim wrote:
....will order carb rebuild kits as well. anybody ever buy parts from BABBITTS any good?...
A few folks haven't been very pleased w them. FYI: in their parts diagrams they list a price for everything, but they do not have & cannot get a lot of that stuff. They'll take your money, send an incomplete order of whatever they happen to have, then let you know about the unavailable parts later... kinda deceptive.
Z1Enterprises.com is a good place to get stuff for the bike & the customer service is great. I don't know if they (or anyone) have rebuild kits for the 81 CSR. You could buy the gaskets & starter plunger caps, and get a metric o-ring kit from HarborFreight or somewhere (nitrile or viton rubber). And see if Z1 can get the starter plunger o-rings - not sure if Kawasaki still lists them as Active (Z1 can get dealer parts).
Or to save trouble finding the o-rings, CycleOrings.com is operated by a guy who sells kits that have the correct size o-rings. The HF/etc metric kits don't have exactly the same size as stock, but they'll work.
26 Oct 2010 05:55 #409128 by kawsakiman
Replied by kawsakiman on topic #1 cylinder not getting hot
Best parts source,
Good Fortune! :)[/quote]
your not seriously telling him to use an impact driver on carb drain screws are you? :blink:
26 Oct 2010 06:37 - 26 Oct 2010 09:20 #409132 by Patton
81kzjim wrote:
...could not get drain screws to turn on #2/#3/#4 any ideas how to loosen drain screws? sprayed with wd40 will try again tomorrow....
Patton wrote:
...blah blah blah...impact driver...blah blah blah....
kawsakiman wrote:
...your not seriously telling him to use an impact driver on carb drain screws are you? :blink:
Would not invite Godzilla to do it. :pinch:
But would resort to a delicate subdued application as opposed to otherwise damaging slot in the screw head which could necessitate drilling out and replacing the screw.
Not talking sledge hammer force against float bowl here.:lol:
But am maybe overlooking some other option where correct size screw driver won't loosen the screw when twisted to the point of damaging the slot. For instance a judicious application of heat (not open flame), or perhaps apply some dry ice to the screw head before attempting to remove?
What other alternatives might be recommended before gentle persuasion with an impact driver? :unsure:
And BTW, would apply PBBlaster or Kroil or 50-50 Acetone/ATF instead of WD40, although WD40 might help a little.
Edit -- or Liquid Wrench as later noted by JMKZHI, which I had forgotten about.
Good Fortune! :)
Last edit: 26 Oct 2010 09:20 by Patton.
26 Oct 2010 07:26 #409141 by 81kzjim
thanx for the idea i have impact driver,also thanx for fuel tank tutorial,parts will look into
jim.
1981 650 csr
26 Oct 2010 07:37 #409143 by 650ed
Patton wrote:
...some other option where correct size screw driver won't loosen the screw when twisted to the point of damaging the slot...
I think you have hit on the issue here. I seriously doubt that the correct size screwdriver is being used; otherwise the screw will come out. It takes a very large screwdriver to fill the slot in the drain screws, but such a screwdriver will loosen the screws because of the high torque it can apply. Ed
