Bike Starting Issue
  • gd4now
  • Denco where did you go?
23 Oct 2010 21:20 #408654 by gd4now
Replied by gd4now on topic Bike Starting Issue
Have not seen any further info here - but thought I would pass this on. There is a pretty good write up on kz650.info on how to do a starter clutch rebuild. This link should take you to it. forums.kz650.info/index.php?action=dlatt...pic=586.0;attach=873
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
24 Oct 2010 06:59 #408696 by Tracker
Replied by Tracker on topic Bike Starting Issue
Just curious...
The starter clutch sprocket spins freely by hand to the left [front of the bike] and CAN NOT be spun to the right (rear of the bike) by hand. The starter spins it to the right (if I figured it correctly) so wouldn't that mean that the clutch is working?
If I am correct then could it be that the starter needs rebuilt?
Is there any way to check the starter aside from just connecting it to a battery. Once connected to a battery the starter spins but makes a LOT of noise... at one point it made a squealing type of noise.
24 Oct 2010 10:28 #408723 by Tracker
Just to add..
I took apart the starter and there was a lot of black carbon like buildup and the positive side of the brushes that connects to the positive bold has a large chunk that was broke off...
Im guessing that I should start with rebuilding the starter?
  • gd4now
24 Oct 2010 12:41 #408744 by gd4now
It sounds like that is a good place to start.
1977 KZ650 B1
  • TeK9iNe
  • What did you do!?!
24 Oct 2010 15:03 #408785 by TeK9iNe
Replied by TeK9iNe on topic Bike Starting Issue
apeman wrote:
I have done this fix twice. The first time I just replaced the rollers and springs. That fix lasted a few thousand miles. The second time I did it right and replaced the entire assembly. The job is an all-day job, even if you have the parts sitting right there on your workbench ready to go. You will be tired when you are done. Get the entire assembly and do it right the first time.
:blink: All day job! My boss would fire you... :laugh:
Peace! :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
25 Oct 2010 15:49 #409010 by apeman
Replied by apeman on topic Bike Starting Issue
Peace! :laugh:[/quote]
Yeah, I don't claim to be a speed tech. Just an amateur who plods his way through using simple hand tools, some research and a little ingenuity. Good thing I don't do this for a living.
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
  • gd4now
25 Oct 2010 17:19 #409032 by gd4now
Tracker - any progress on the starter issue?
1977 KZ650 B1
25 Oct 2010 17:23 #409036 by Tracker
The parts shop was closed today I am gonna go down in the morning and order new brushes and such to rebuild the starter hopefully have something done soon. I want to ride it so bad :P
Only been able to put 500 miles on it since I bought it [had it about a month] I knew something was acting up when I bought it but was hoping to get a little more out of it... Oh well thats what I get for being cheap :P
I still cant complain for $400
Here is my bike if anyone is interested :)
It has clamp on filters and the correct battery now tho :P
  • gd4now
25 Oct 2010 17:44 #409042 by gd4now
Great looking machine. You can still push start it and ride till you get the parts.
1977 KZ650 B1
25 Oct 2010 18:08 #409048 by Tracker
I have a hell of a time getting it into 2nd gear when the engine is not running... any tips? :P
  • gd4now
25 Oct 2010 18:12 #409050 by gd4now
It may not go into 2nd when not running. The times I have pushed started mine I used 1st. Held in the clutch pushed it and jump on and dumped the clutch and when it fires pull the clutch back in again.
1977 KZ650 B1
25 Oct 2010 18:14 #409051 by Tracker
The parts should be here on wed. I think I MAY wait it out if temptation does not kill me first :P
