Need help identifying header
- KZPens
18 Apr 2006 19:27
Got this header today, I have no clue what brand it is. The 2 springs for the lower tubes are missing, knowing the brand should help me locate some. I would really appreciate if anyone could tell me who made this header.
Thanks
Thanks
- reborn650
Re: Need help identifying header
18 Apr 2006 20:35
Hi KZPens. My guess is the pipe is from Yoshimura. From the pic you posted it looks like the one I had on my 650 back in the mid 80's. Mark Wing has one on his bike and he might have an opinion also. Try posting a few other pics from the top and the front. This will be of help.
'77 Kz 650 Custom - (Miss July on 2006 Kzr Calendar,) Newest rebuild includes Wiseco 810 kit, Kz750 cams, Kz750 intake valves, 750 GPz springs, Ported head, WG Mikuni 28's, Velocity Stacks, Dyna Ignition and coils, MAC pipe, 14 tooth sprocket, going back to original '77 Moon Dust Silver. Goal is to have a stock-looking bike that will tighten up any loose dental fillings off the light.
-1998 Jeep TJ Wrangler 4.0...
- wireman
18 Apr 2006 20:57
the yosh pipes ive seen have flat steel mounting flanges on them,those look like stock collars.were 650s differant than 900-1000?
- KZPens
18 Apr 2006 21:17
The mounting flanges are flat, hard to tell in that pic, here is a link to a higher res pic 1.3MB
pic
I'll take some more pics tomorrow, thanks so far for the help.
Post edited by: KZPens, at: 2006/04/19 00:21
Post edited by: KZPens, at: 2006/04/19 00:23
pic
- wireman
18 Apr 2006 21:40
those are cast iron,the other ones are like 3/16th steel plate.
- Fossil
18 Apr 2006 22:31
Can't tell you what it is, but I can tell you it doesn't appear to be a Hindle, that might narrow it down a bit.
- KZPens
19 Apr 2006 18:20Please Log in or Create an account to join the conversation.
- wireman
19 Apr 2006 21:24
well ive got a picture of a yosh eader but i cant make it fit!:S
Post edited by: wireman, at: 2006/04/20 00:25
Post edited by: wireman, at: 2006/04/20 00:26
- steell
19 Apr 2006 22:34
It looks like the Yosh pipe I removed from the GPz750, although I can't tell how thick the flanges are in the pic, like wireman said they were pretty thin, 3/16" or so.
- Mark Wing
20 Apr 2006 00:33
The early Yosh pipes like mine, the collector isn't angeled like that one. It comes straight back then the back half kicks it out to the side. The later pipes collected on an angel like that but I'm not sure about the four head pipes moving like that. Here's a pic of a Yosh Ninja 600 pipe.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- loudhvx
20 Apr 2006 07:59
Either way, you should be able to throw on any good spring from a hardware store, no?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- solomrus
20 Apr 2006 08:52
i'd put some money on that being a moriwaki.
the yoshi collectors are a one piece affairs, not like that multi piece one you have.
the flanges look like the mori cast aluminum ones that i see on the JDM auctions. the mori's are also separate tubes to the collectors like this one. not many other's are like that.
similar to this one, the flanges are different on this particular setup tho.
pm me, i might have some springs that'd work for that. or, go to your local bike shop(the speed shop),they'll most likely have a few.
--r
Post edited by: solomrus, at: 2006/04/20 11:58
--r
198o kz1ooo Bravo Four
