Gpz 750 Cylinder Head and Valves
- gpzman2000
I used to throw a few posts to You on drag bike, back when I worked at the Crystal Cathedral.
Good to see you here, too ! What's new ? How's life at APE ?
- Becker
- The Doctor Will Rise Again
- Thank you received: 1
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
- turboguzzi
- Thank you received: 72
if your valves are sunk a bit into the the head, would take care to measure installed spring length and and adjust with shims back to measure. if the installed spring height is to big your spring preload will be lower and you'll have a higher risk of valves floating
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- gpzman2000
I am being very deliberate, careful and cautious on how I go about re-assembling this engine. I've had this motor torn apart at least a dozen times over it's lifetime. This aint' my First Rodeo !
That being said, I will make certain that the split keepers will not interfere with the retainers. Again, my goal here was to machine just a small margin, to permit the shim selections to be above 200.
If I end up taking off too much, then it will be time to get replacement valves. No biggie. Better safe than sorry.
- gpzman2000
- larrycavan
- Visitor
All of the seats and valves were machined by a skilled motorcycle machinist. After measuring the installed height, it was clear to me, the I was going to run out of shim selections. Nothing available below 200.
I wouldn't go this route but if you call Web Cams they probably have some 180 or 185 shims. They used to anyway...
