Gpz 750 Cylinder Head and Valves
- gpzman2000
My question is: The installed valve heights are almost at maximum. I was told that an alternative would be to machine the valve tips, a few thousandths.
Will this technique work ? I know that by shaving off a few thousandths, I will have the clearances I need, and I won't have to use the 2.00 shims.
Suggestions ? comments ?
- cafekz750
I haven't had it done before, but I believe a member "Bountyhunter" has had it done to his KZ750 (twin) as those shims are hard to find.
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
- MFolks
- Thank you received: 540
www.kawasakimotorcycle.org/forum/mechani...ding-valve-shim.html
- gpzman2000
- Thank you received: 2098
- Becker
- The Doctor Will Rise Again
- Thank you received: 1
Anyway, we didn't machine them. We used a vale grinder that had a setup for it. It worked really and gave me a lot of control on how much I took off. Good luck with it.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
- gpzman2000
I don't plan on riding this bike much. I just want to restore it, and maybe put 500 miles a year on it.
If memory serves, I used to adjust the valves about once every 1500 - 2000 miles on this bike.
I hope that I don't end up doing a valve adjustment every 500 miles !!!
- larrycavan
- Visitor
So, if I machine .004" from the tips... how badly will this affect wear on the valve tips ? ( Since the hardened material will be removed at the tip ).
PAY ATTENTION HERE
.004" is nothing. It's 2 shim sizes. You should't need to touch the valve stems for 2 shim sizes unless you were way down under 220 shims before the valve job was done.
There are some things about the 750 that are worth taking note of.
1 - cams with different base circle sizes were used on some GPz models. Measure your exh and intake cam base circles. You might find the exhaust is smaller.
2 - the OEM manual has incorrect information in it regarding installed height. That's not unusual with service manuals. It was common for Kawasaki to send us corrections to the manuals after they were printed.
IF you decide to tip the valves, they need to be done on a grinder that will grind the tip perfectly flat and perfectly perpendicular to the stem.
If they are cocked, it can cause shim fracture.
Since you only need .004" taken off....if your shim size is 230 or thicker to bring lash into spec....and if you can't grind the stems correctly....LEAVE THEM ALONE.
OTHER S.O.B. SETUP ISSUES THAT CAN HAPPEN
It's possible to run valve tip to retainer top edge problems with SOB motors....if that happens, valves can be dropped.
Put a retainer on the valve with 2 keepers and pull the retainer up tight. Install a 200 shim in the retainer.
If the shim sits below the top of the retainer by more than .004", there are issues that you cannot solve without the proper equipment.
It's not likely you'll run into that last scenario ....just making you aware of what can happen sometimes.
- APE Jay
- Banned
- Thank you received: 58
- Injected
- Thank you received: 543
Since you measured it, you have some sort of spring in place all ready... it's just easier to rotate with light springs.
There are several ways/tools to use to do that measurement and some can be off by a few thou depending on how it's done.
From what I know Kawasaki valves are very hard buggers and I have never heard of having to do any heat treatment after any kind of grinding on them...
- gpzman2000
I matched up the retainers to the valves (outside of the head ), and noticed a very tiny clearance between the tips of the valves, and the top of the retainers.
I did check the original Kawasaki manual for this ( not a Clymer, but the Kawasaki manual ), and cross-referenced the chart + shim size + installed valve height.
I figured that .004" is erring on the side of caution, as I know that it will bump the adjustments only +2 shim sizes. But again, this bike will see VERY FEW miles in the remainder of it's service life. I figure that it will see no more than 100 - 200 miles per year, at very most. Therefore, I want to make sure that 1. the clearances are within spec 2. not to have my machinist remove too much material 3. not to have a clearance issue between valve tips and retainer tops.
The bottom line is: If I have too many problems with these valves, I can easily replace them. ( although I am trying to conduct this project on a modest budget ).
Thanks for the input.
- larrycavan
- Visitor
This cylinder head has seen x3 valve jobs, over it's lifetime. The shim sizes installed prior to the valve job were 215 - 220.
Based on this latest information, IMO, I would install new valves....but good luck with whatever you ultimately decide to do.
Make sure you're not stepping over dollars to save dimes
