Ceramic header coatings and performance.
- otakar
05 Oct 2010 18:41 #404361
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Ceramic header coatings and performance.
From what I understand, .002 is about the max limit. You can experience cracking if you go past that. Most places go .001+-.0005" on each side. with time the coat will start to dull but can be re-polished.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- loudhvx
- Thank you received: 1616
05 Oct 2010 20:41 #404392
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Ceramic header coatings and performance.
How much prep do you have to do if any before bringing it to them? Is it cheaper if they only do the outside?
I'm really only concerned with rust on the outside. When I repaint the header black, the header pipes turn gray right away and then rust starts to show up in about 7 or 8 months. But mostly it's from condensation on the outside from sitting in the garage. The insides don't show much rust at all.
I checked out the link, but I assume you got more info from them directly. They say the coating forms a "sacrificial layer". Does this mean the coating disappears over time?
1981 KZ550 D1 gpz.
Other links.
- dutchz
- Thank you received: 4
05 Oct 2010 21:25 - 05 Oct 2010 21:51 #404394
by dutchz
1974 Kawasaki Z1
Stock front hub and rear axle.
Replied by dutchz on topic Ceramic header coatings and performance.
I had the pipe I built coated. They sand blast before coating just like they would for regular powder coat. I don't know how much of a difference in performance it makes but it sure looks better than VHT paint.
Before:
Before:
1974 Kawasaki Z1
Last edit: 05 Oct 2010 21:51 by dutchz.
- dutchz
05 Oct 2010 21:26 - 05 Oct 2010 21:52 #404395
by dutchz
1974 Kawasaki Z1
1974 Kawasaki Z1
Last edit: 05 Oct 2010 21:52 by dutchz.
- loudhvx
05 Oct 2010 23:37 #404409
by loudhvx
1981 KZ550 D1 gpz.
Other links.
That does look really nice, though I gotta admit, I start fixating on all of the other details on that green machine! :woohoo:
I wonder what the chip-off factor is like, and if it does chip, how do you fix that? Can they coat small chips and nicks as a repair, or do they have to redo the whole thing?
1981 KZ550 D1 gpz.
Other links.
- dutchz
06 Oct 2010 09:55 #404485
by dutchz
1974 Kawasaki Z1
I've only been riding it since July, about 1600 miles (guessing, no speedo :laugh: ) and so far no chips. I assume it will be the same as powdercoat, they have to do the whole thing. It seems like a pretty tough finish though.
1974 Kawasaki Z1
- otakar
06 Oct 2010 14:34 #404589
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Hay Lou, They told me that they do all the prep work. It is worth to do them inside and out. If you have chromed pipes than just have them done on the inside and prevent them from bluing.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- loudhvx
06 Oct 2010 14:40 #404590
by loudhvx
1981 KZ550 D1 gpz.
Other links.
That's a great deal then if I can just bring in a rusty pipe.
I have one pipe that looks chrome, but it's like black chrome. I'm not sure what that is, but it looks great. It still has small rust spots where it got dinged or scraped. But any idea what finish that is? The grab rail on my 550's came with that same black-chrome finish.
That's one pipe I may only want to do the inside.
1981 KZ550 D1 gpz.
Other links.
- otakar
06 Oct 2010 15:00 - 06 Oct 2010 15:01 #404599
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
I am not sure what Kawaski used on the black header pipes. BTW, I got the job at RIM.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 06 Oct 2010 15:01 by otakar.
- loudhvx
07 Oct 2010 01:02 #404776
by loudhvx
1981 KZ550 D1 gpz.
Other links.
The black-chrome header is an aftermarket I think. I bought it off a salvage bike. The Kaw ones I had were just painted, but with some sort of decent paint.
Congrats on the job!
1981 KZ550 D1 gpz.
Other links.
- kbex
07 Oct 2010 14:42 - 07 Oct 2010 14:43 #404993
by kbex
1978 KZ1000A2
Replied by kbex on topic Ceramic header coatings and performance.
Not a ceramic product, but POR 15 Factory Manifold Gray works fantastic. I used it on the pipes I built for my street tracker, and it is a miracle product. I've used it on cast iron manifolds, with equal success. It requires blasting, to adhere properly, and some careful curing, but I love it. The only draw back, is it only comes in gray. I sprayed my pipes, but it is self-leveling, and applys well with a brush. Not as good as ceramic, but you can touch it up, if/when you chip it. (the inevitable chip, or "Oops, I need to weld a bracket on, are my only gripes about ceramic pipes, or powdercoated frames) They have other products that are black or silver, but I have not tried them. I'm with you on VHT, I wouldn't pain my BBQ with that stuff. It was too spendy at $2.99 per can, let alone the 8 bucks they want for it now. Good luck! Kyle
1978 KZ1000A2
Last edit: 07 Oct 2010 14:43 by kbex. Reason: pic too large 1st try
- otakar
07 Oct 2010 15:38 #405007
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
I too have the POR-15 product sitting here. I just don't like the color. I have also learned to mistrust POR-15 products. I have used every silver coating that they have and ALL of them remained tacky indefinitely. I however love their black products. They are as good as powder coat.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
