JUGS!!!!
- kz1k
- You Cant Fix Stupid!
30 Sep 2010 19:27 - 30 Sep 2010 20:08 #403007
by kz1k
1978 KZ1000A2
JUGS!!!! was created by kz1k
too bad i cant post boobies...lol
alright. i have jugs that a couple of the sleeves are not presses in anymore. one can be removed from the jug by hand. in my demonic mind i figured either i would need to buy another jug that had the same bore to match my pistons, with sleeves pressed. or i would have to send out my jug to be repaired.
i guy i was talking to told me not to do either one of those things. he told me that the head bolts will keep my head pressed against the 'collars" of the sleeves and they will be seated flush like they should be.
in my wallets opinion, he was right, but it sounded like a quick temperary fix. can i get some advice on what i SHOULD do? thanks....Joe
1978 KZ1000A2
Last edit: 30 Sep 2010 20:08 by kz1k.
- MFolks
- Thank you received: 540
30 Sep 2010 20:38 #403017
by MFolks
Replied by MFolks on topic JUGS!!!!
If it were me, I'd check with the machine shops that work on older bikes.
Motorcycle Machine Shops
www.aperaceparts.com
www.bore-tech.com
www.flowbenchtech.com (Cavenaugh Racing Heads)
www.fastbygast.com
www.grccranks.com
www.schnitzracing.com
www.valleyspeed.ca/services.html
racetoolz.com/
www.carolinacycle.net/index.php?option=c...ex&Itemid=3&catID=84
www.maxrpms.net/shop/
This website is well known for quality products(LA Sleeve).
www.bikebandit.com/brand/l-a-sleeve
www.bore-tech.com
www.fastbygast.com
www.grccranks.com
racetoolz.com/
- APE Jay
- Banned
- Thank you received: 58
- Thank you received: 797
01 Oct 2010 05:49 #403052
by 531blackbanshee
Replied by 531blackbanshee on topic JUGS!!!!
kz's are known to have loose sleeves.the head gaskets should hold them in place.lay a straight edge across and as long as they are flush or possibly sticking up some they should stay put with some good fiber head gaskets.thats my .02,
- kz1k
01 Oct 2010 05:51 #403053
by kz1k
1978 KZ1000A2
Replied by kz1k on topic JUGS!!!!
thanks banshee
1978 KZ1000A2
- PLUMMEN
- Thank you received: 104
01 Oct 2010 07:38 #403071
by PLUMMEN
Replied by PLUMMEN on topic JUGS!!!!
