Exhaust System
- mtbspeedfreak
Exhaust System
28 Sep 2010 11:13
Hi guys! Quick question for y'all:
One of my 4-into-2 exhaust mufflers fell off; now it truly sounds like a "muscle bike" for sure.
I had been eying up a 4-into-1 exhaust system for quite some time now, what you you guys recommend? I'm riding a '76 KZ 900: the carbs are jetted, but fouls plugs more often than I'd like so I need to rejet it regardless. I have a K&N airbox filter- not the individual pod filters. No other internal engine modifications have been done.
I'd like to emphasize that ride this bike- I've tacked on 10,000 miles since June 1st, so I'm looking for a system that not only performs well and looks good, but holds up on multi-day, thousand-mile trips over the hills and through the woods.
I'm thinking Kerker or Vance & Hines, but open to nearly anything.
Thanks in advance for your recommendations! I appreciate your advice.
-Mark
-Mark
2000 ZRX 1100
1976 KZ 900- Daily Driver
- TeK9iNe
- What did you do!?!
Re: Exhaust System
28 Sep 2010 11:42
MAC systems are ok, and inexpensive. Broad range power.
V&H are good for some mid-high end grunt, better for street and all-around riding.
The Kerker pipes tend to really scream up high in the rpms, not as much notice in the mid power.
your choice really, as I believe they will all hold up for very long, if well maintained.
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Mcdroid
- Gone Kwackers
Re: Exhaust System
28 Sep 2010 12:06 - 28 Sep 2010 12:10
I'd add to TeK9iNe statement that the only active manufacturer of the three brands he mentioned is MAC. Both Kerker (= Supertrapp) and V&H have dropped the Z1/Z900 pipe from their lineup. These latter pipes are still available but as excess stock at third-party vendors (check eBay).
EDIT: and just about any brand ever produced pipe-wise is available on eBay as used...patience will produce some amazing finds...i.e. Yoshimura...Bassani...Hooker, etc.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 28 Sep 2010 12:10 by Mcdroid.
- KZ1979LTD
Re: Exhaust System
28 Sep 2010 13:34
One of the members here has an old Yoshimura (70's?) in the classified ads on this site. I have one just like it on my KZ 1000 and I love it. It sounds good with or without the baffle and looks good too. The one he is selling looks to be in excellent shape. I can't believe no one has snatched it up yet. The only drawback is the pipes location, when mounted on the bike, hinders you from changing the oil filter without taking the pipes off. My two cents.
Re: Exhaust System
28 Sep 2010 14:05 - 28 Sep 2010 14:06
Before addressing carb jetting,
would first assure:
-- full battery voltage reaching coils;
-- properly timed fat blue spark;
-- correct valve clearances;
-- correct fuel level (clear tube method);
-- freshly serviced air filter;
-- pilot air screw adjustment (try slightly leaner setting);
With 4>1 exhaust system, existing jetting might be okay.
Considering mileage being ridden, and oil/filter maintenance schedule, would select an exhaust system that allows changing both oil and filter without requiring removal of the exhaust system.
would first assure:
Last edit: 28 Sep 2010 14:06 by Patton.
- Bakes
- Z1 Enterprises Customer Service Guy
Re: Exhaust System
28 Sep 2010 14:22
Mark,
Although tough to find evidence of such - both Kerker and V&H are still producing pipes - at least for the Z1s / 900s.
Available "visual evidence" would support the NLA claim but as far as we know, there are no plans in the immediate future to end the production.
I should have a chrome system (Z1, KZ900, KZ1000) in stock by mid to late next week.
No shameless plug here - Mark and I already talked via phone.
The idea of a Yosh is by all means intriguing! :woohoo:
Best of luck Mark.
Best of luck Mark.
Bakes <><
Re: Exhaust System
28 Sep 2010 14:54
Bakes wrote:
Mine got less intriguing with every oil and filter change. :laugh: :laugh: :laugh: :laugh:
But beautiful, so very beautiful.
...The idea of a Yosh is by all means intriguing!....
- Gman
Re: Exhaust System
28 Sep 2010 17:15
I vote for the Kerker with street baffle for a daily rider. They have oil filter access and you can keep the center stand. Although expensive, it's worth it if you have the funds.
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
2002 Gold Wing
1974 Z1 900 project
- kaw a bong a
- Have a 1978 kz 650 b and a 1976 kz 900z1ltd
Re: Exhaust System
28 Sep 2010 18:45
I have the V-n-H on both my 650 and 900 add just installed a comp baffle in the 900 and an realy lovin the sound and power im layin down.
1978kz650b 1976kz900 first bike 1979kz 400
- mtbspeedfreak
Re: Exhaust System
29 Sep 2010 12:03
Hey guys, thanks for your input. I'm strongly leaning towards a Kerker- oil changes and easy chain lubes are pretty important to me. What sort of power gains does this system provide- a little mid-range twist and some high-end power? Has anyone gone insane from 12 hours in the saddle of listening to the Kerker scream? :lol: The competition baffle would be fun on weekends
Patton, I've tried most of those routes: new Yuasa battery, Dyna S and 3 ohm coils, NGK BR6IEXs (Iridium's), MSD 8.5mm wire, and a K&N airbox filter. I've only tinkered with the pilot air screw adjustment- I think I'll hold off on any more tuning till the Kerker's on. I'd imagine straight pipes require slightly different tuning than any system with a muffler.
Not to go off subject, but I've noticed that when I'm higher up in the RPMs, the headlight and indicator lights (I'd imagine the tail light as well, but I've never turned around to watch
) get brighter as the RPMs increase. Is this common? It makes sense to me but I'm wondering if I may have bigger voltage regulator/electrical problems. Also, when I'm on my longer trips, the battery weakens- this past trip I wound up kicking it over the last morning- electric start works fine when she's warmed up. Granted, it's been friggin HOT 'round these parts lately so I'm not worried, but I think I've noticed that when I'm running my high beam (I usually run with my high-beam always on; Sylvania Silver Star car headlight) the battery drains faster. As opposed to not having the headlight on as well, which I do on occasion when it's really hot (+100 degrees).
Thanks!
Thanks!
2000 ZRX 1100
- hocbj23
Re: Exhaust System
29 Sep 2010 13:23
Pipe alone probably wont produce much of a gain.Pipe plus rejetting plus box with a K and N or pods might give u an extra 5-7% increase.worth it? Only if u plan on keeping the bike awhile.All the above plus a good set of street cams and u should really see improvement.V and H was my choice,but I had to modify the brake pedal for clearance.bj
- kaw a bong a
Re: Exhaust System
29 Sep 2010 15:10
You could have a weak battery,mine went bad on me,If the bike didnt start right on the first or second try I would have to kick it, and ran good warmed up,but eventually died,bought a new one and no problems ever since.The one that died was a wally world type.only 6 months old.but you might have bigger issues.
