J Motor KZ1000 O-Rings At Oil Pressure Switch
- Motor Head
28 Sep 2010 07:12 - 28 Sep 2010 10:29
OK so basically if you haven't changed the O-rings at this Fitting Block, right under the cam chain tensioner, then I say you better. I've had both bikes Start to leak here when a cold start is done. Remember these have a low oil pressure system, like 3psi. So if it leaks the O-rings would be Fubar. I've found them to be hard as a rock.
So If you are getting one running, or pulling your carbs for service, or just want to replace them before it starts to leak, I would do It. If you have a Metric O-ring kit in your work area, then you should have the correct sizes without ordering anything. Takes a couple minutes to do even with the carbs on. 2 allen head bolts, and a 6mm allen key, or socket will remove it.
Sometimes you just don't think about these sort of area's when you do a Top End, as the O-Rings wouldn't be in that Gasket Set, you would get them in a Complete gasket set.
Last edit: 28 Sep 2010 10:29 by Motor Head.
- TeK9iNe
- What did you do!?!
Re: J Motor KZ1000 O-Rings At Oil Pressure Switch
28 Sep 2010 07:58
:laugh: That'l teach ya.
Replace ALL rubber folks...
Cheers.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Sandy
- Fly High,Tony
28 Sep 2010 08:00
Good to know and worth keeping an eye on for sure.
Replaced mine not too long ago,when I installed my oil-cooler.
1977 KZ1000 A-1
- otakar
29 Dec 2010 06:56
You can really loose a lot of oil threw these. I have been postponing replacing mine just due to laziness. I get a big puddle of oil on top of the case in no time. I will swap them out with "Viton" rings when I put the bike back into service this spring.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- grumpy56
29 Dec 2010 12:15
My O rings didn't appear "hard", but they sure were squished.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- RonKZ650
29 Dec 2010 19:06
All the orings are smashed and hard as a rock on these 30 yr old engines by now. The more miles, the more heat and more chance of leaks. Most will not leak if you don't fool with them, or if they do it will be minor amounts. A KZ1000 uses much less rubber than a KZ650 thankfully. On a KZ650 I never try to guess which orings are going to leak, as there are at least 50 of them. You KZ1000J guys are lucky as you have only 20 or so.
- 9am53
- homebrew, and some bbq
30 Dec 2010 04:37
When I first put my motor together last winter I took it out for it's fist ride. Somehow the little pressure switch oring had gotten squished in crooked...Luckily I only went around the block because I lost almost half my oil in about 3 monutes. When looking down for oil leaks I always look somewhere around the head area so I missed the river of oil spilling out behind me!
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
- grumpy56
30 Dec 2010 08:15
Can one of you guys snap me a photo of what your oil pressure switch housing (without an oil cooler line attached) looks like? I may be disconnecting my cooler at least until I can get a new oil line.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- Motor Head
30 Dec 2010 08:26
motors.shop.ebay.com/i.html?_nkw=KZ+oil+...sid=p4506.m270.l1313
This link has several on FeeBAy. 81 up.
- grumpy56
30 Dec 2010 10:24
Thanks Motor Head. From what I can see, the front part of the housing just has a plug with a rubber O-ring. I guess I can just plug mine up and ride off.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- Vintage3
15 Apr 2015 12:57 - 15 Apr 2015 18:55
When replacing these gaskets, are the allen key bolts just hand tightened? Thanks.
Last edit: 15 Apr 2015 18:55 by Vintage3.
15 Apr 2015 15:36Motor Head wrote: motors.shop.ebay.com/i.html?_nkw=KZ+oil+...sid=p4506.m270.l1313
When you see that silver dollar in the ad, avoid him. He sells junk at the highest prices he can.
