Engine warm-up
23 Sep 2010 11:37 #401195 by 83kaw550
Engine warm-up was created by 83kaw550
83 KZ550m1 13,000 miles,
When cold: it starts right up with choke out all the way out, but likes to rev around 4500 rpm's until its warm enough to push the choke back in. The time that it takes to do this seems considerable to me(2-4 miles down the road). Is this normal?
  • 9am53
  • homebrew, and some bbq
23 Sep 2010 11:50 - 23 Sep 2010 11:50 #401199 by 9am53
Replied by 9am53 on topic Engine warm-up
These bikes can take a while to warm up. If I were you I would let the bike warm up before taking off. If the bike is idling around 4500 and you shift into 1st it must be a hell of a shock on the tranny/clutch! I live in a colder climate and now that temps are dipping to around freezing at night I let it idle on full choke for about 15 seconds, then I push the choke in half way and rpm's go to around 1500. I go inside and put my boots/jacket/helmet/gloves and glasses on. This takes me a few minutes, then I push the choke in all the way. My idle drops to around 700, and I take off. I think it is probably better on the motor to get a good chance to warm up and get oil flowing before riding away.
Last edit: 23 Sep 2010 11:50 by 9am53.
23 Sep 2010 12:02 #401200 by TerryK
Replied by TerryK on topic Engine warm-up
Like our Viking friend says, push the choke back in until it's idling about 1500. You can ride when it will idle without the choke.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
23 Sep 2010 12:31 #401204 by 83kaw550
Replied by 83kaw550 on topic Engine warm-up
Thank you for the info you two. Do your bike idle this high though when you start them? 4500 rpm's seems and sounds like a lot to me for. I know it will hold this rpm for at least 5 minutes or more... I got tired of it and rode it for 4 miles and when returning home it seemed to idle just fine then. Maybe I'm being just too picky... Thank in advance for any further insight.
Scott
23 Sep 2010 14:54 #401228 by 83kaw550
I found a plastic round turn-knob underneath and right in the middle of the carbs. Is this the idler screw? I can get a picture of it later if needs be.
Thanks,
Scott
23 Sep 2010 15:03 #401234 by Patton
Replied by Patton on topic Engine warm-up
83kaw550 wrote:
I found a plastic round turn-knob underneath and right in the middle of the carbs. Is this the idler screw? ....
Yes, that's used to set the idle speed at desired rpm when the engine is running at normal operating temperature.
The bell-crank (where throttle cables attach) stops when it meets the tip of the adjuster screw, which prevents the carb slides from lowering any further.
Good Fortune! :)
  • Motor Head
23 Sep 2010 15:05 #401235 by Motor Head
Replied by Motor Head on topic Engine warm-up
RPM of that range when the choke is on sounds like its got a vacuum leak at the manifolds. Check for vacuum leaks and repair as necessary.
23 Sep 2010 15:21 #401240 by 83kaw550
How could I be sure there is a leak? How do I check?
  • Motor Head
23 Sep 2010 15:23 #401242 by Motor Head
Some spray WD-40 around the boots and look for smoke at the exhaust. Me I use brake clean or carb cleaner and spray it around the boots and check for a RPM change.
23 Sep 2010 15:47 #401246 by 83kaw550
I appreciate the tip. Thank you.
  • kzz1p
  • One Test Is Worth A Thousand Expert Opinions!
23 Sep 2010 15:53 #401247 by kzz1p
Replied by kzz1p on topic Engine warm-up
If everything checks out well, and you don't have a vacuum leak. I would install some larger pilot jetts, it would cut down on the amount of choke needed.
  • 9am53
23 Sep 2010 16:12 #401248 by 9am53
since it is cold out now I need full choke to start my bike, and it will initially be up there somewhere around 4000 rpm's, but give it like 20 seconds at that speed and it starts to bog hardcore, way too rich, then when it goes in halfway it idles at 1500 nice and smooth, gets the oil flowing and doesn't bog. Just for curiosity if you let it idle for a minute at full choke what happens? These old bikes need some time to warm up, give them a couple minutes...my carbonated pickup takes a really long time to warm up in the winter, and since it has an automatic pedal style choke you can't just close it early, so a couple minutes for the bike is nothing.
