Engine warm-up
- 83kaw550
- 9am53
- homebrew, and some bbq
- Thank you received: 3
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- 83kaw550
Scott
- 83kaw550
Thanks,
Scott
- Thank you received: 2098
I found a plastic round turn-knob underneath and right in the middle of the carbs. Is this the idler screw? ....
Yes, that's used to set the idle speed at desired rpm when the engine is running at normal operating temperature.
The bell-crank (where throttle cables attach) stops when it meets the tip of the adjuster screw, which prevents the carb slides from lowering any further.
- Motor Head
- Thank you received: 391
- 83kaw550
- Motor Head
- 83kaw550
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- 9am53
'84 GPz900r
'71 CB350
