- Thank you received: 337
Engine oil, brake fluid
- bountyhunter
Amen. Bikes subject the oil to severe service similar to taxis, and they used to spec a service interval of 3 months/3000 miles (whichever came first). If you do a lot of city short trip riding, IMHO oil should be changed at an absolute maximum interval of six months regardless of mileage.As long as the oil grade and weight are correct, you're best bet is to change it on a regular basis. Many times I've seen people buy the most expensive oils and just leave them in their machines way past the time they should have been serviced.
- bountyhunter
That's almost a philosophical question. IMHO, very good dino oil with a strong additive package like Rotella is perfectly fine for bikes as long as it is changed at a proper interval. In engines subject to sever service or very hot environments and lots of stop and go riding, I think the extra cost of true synthetic is justified.15W40 Synthetic or Petro?
- bountyhunter
That surprises me, I would be surpised it falls apart in only 1k miles. I have read that Rotella is diesel rated and has a very strong additive package, including the viscosity enhancers. I have seen other bikers running it and sending it out for analysis and it held up very well at long mileages like 5k - 6k. Bikes do rip up the oil pretty badly, a good argument for not running it long mileage.Paint is not original. That bike only came in two tone pink or green/purple with flames.:laugh:
Well I think my memory may be fading on that model, but 100 percent certain that paint is not original. Oil is pretty forgiving. I don't particularly like the 5w40 Rotella as it shears to a 5w20 in a thousand miles. maybe that does no harm, but I don't like it. The 15w40 oil is cheaper and better.
- 83kaw550
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- beefsquasher
-Dave
1977 KZ1000 Mutt - 1075, Kenny Harmon Cams .400", RS34, Kerker, Dyna S
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- TeK9iNe
- What did you do!?!
- Thank you received: 28
I assure you, DOT 4 brake fluid does a fine job of ruining paint, synthetic or not.
-Dave
+1 Deffinately, I can attest. DOT 3, 4, 5.1 are glycol based and eat everything. DOT 5 is Silicon based, and should only be used in NON-ABS braking systems.
The DOT-5 is the one thats a different tech, and doesnt anhilate paint the way the others do.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
The Shell Rotella-T is what many of us run because it has all the important additives that these bikes require and Automotive oils do not have. It is quite inexpensive at Wall-Mart. As far as brake fluid, any DOT-4 would be good. It is synthetic so it will not eat up your paint if it gets on your body parts like DOT-3 would and it will not settle out water like DOT-5 would to corrode the master cylinder and calipers. As far as Fork Oil gos, I use synthetic Transmission fluid instead of actual fork oil. That is an old Harley trick.
The good Shell Rotella-T (5w-40 blue 4liter bottle), can't be had at the walmart here, but I can still get it at Canadian Tire for cheap!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- RonKZ650
- Thank you received: 240
- PLUMMEN
- Thank you received: 104
biggest thing is to keep it and filter changed no matter what you run.
watch out for Ron,hes a big fan of custom paint jobs !
he thinks everything should be painted with dupli color,i think hes a stock holder! :woohoo:
- TeK9iNe
This is the only one i can get in this format, less I want to buy a drum of the other stuff :laugh:
I've used Amsoil 20w50 for a long time, and it has been an excellent, but expensive product. I went to a regular 20w50, and it was terrible. I've also tried many other oils, and multi-viscosity brands. The Rotella is now the winner for price/performance.
It has LOTS of super heavy duty hard starting additives for diesel engines. I know because a friend uses the stuff in his 17.5:1 compression truck. Everything in that engine has remained spotless and he revs the crap out of it, really kills it.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
