Engine oil, brake fluid
- 83kaw550
- MFolks
- Thank you received: 540
Engine oil : The commercial grade oils are clearly superior to the mass market oils. For the best protection in your bike or car, use Shell Rotella Synthetic, available at Wal-Mart in blue containers . For the best petroleum oil you can buy, get Shell Rotella T, Mobil Delvac 1300, or Chevron Delo 400, available at any auto parts store. On the back of most oil cans is a circular stamp with the certification. Avoid oils that say "energy conserving" in the bottom half of the donut. These oils contain friction modifier additives that could cause clutch slipping over time. All XXw-20 and XXw-30 oils are energy conserving, and should not be used in your motorcycle. Don't buy any oil additives like STP or Slick-50. Here's several listings on all about oil justifying these conclusions.
The Recommended Synthetic Oils :
5w-40 Delvac 1 Synthetic
5w-40 Mobil-1 SUV/Truck Synthetic
5w-40 AMSOil AMF Synthetic (pricey, but it’s your money)
10w-40 Golden Spectro Synthetic
10w-50 Motul 5100 Synthetic
10w-40 Mobil-1 Synthetic
15w-50 Mobil-1 MX4T Synthetic
The best synthetics are: (in no particular order)
Shell Rotella-T Synthetic 5w-40 (blue container, not white), gallon at Wal-Mart.
Mobil Delvac-1 5w-40 (grey container, not black), gallon at Petro stations, gallon at Farm and Fleet.
Mobil-1 SUV 5w-40, qt anywhere.
AMSOil AMF 10w-40 synthetic motorcycle oil. (again, pricey)
Golden Spectro Supreme, (no price).
Motul 5100 Ester, (no price).
Mobil-1 automotive oils all contain small amounts of moly - about 100 to 200 ppm. This can cause clutch slippage in some motorcycles. I've only heard of this being a problem in Honda Shadows.
For temperatures below -40, I strongly recommend either Mobil-1 0w-30 or the Canadian Shell 0w-40 Rotella. At these temperatures, your car is your life. Using cheap or incorrect oil is risking your life.
For temperatures below -55c, -65f, stay home. Really.
The Recommended Petroleum Oils
Chevron Delo 400 15w-40
Delvac 1300 15w-40
Shell Rotella 15w-40
The best petroleum oils are: (in no particular order)
Chevron Delo 400 15w-40 (blue container) gallon at any auto parts store, gallons at Costco.
Mobil Delvac 1300 15w-40 (black container) gallon at any auto parts store, gallons at Sam's Club.
Shell Rotella-T 15w-40 (white container) gallon at Wall-Mart or any auto parts store, gallons at Sam's Club.
If you live in another country, you'll have to do a bit of research to decide on an oil. Generally, any oil certified for use in a late model Volks wagon or Mercedes turbo diesel is a good choice. Another good idea is to go to a truck stop and ask the truckers about brands. Rotella is marketed all over the world, but in other countries it's called Rotella or Rimola or Helix Ultra, and the formulation may be a bit different, depending on local climate and preferences. It will likely also be a lot more expensive than it is here.
Re: Castrol GTX question.
Rotella dyno and synthetic multigrade oils carry the JASO spec. From the Shell web site:
Can heavy-duty diesel oil be used in motorcycles?
Motorcycle gasoline engines may not seem in the same league as the big displacement diesel engine under your hood, but they share some of the same lubrication requirements. So yes, in many cases, a premium heavy-duty universal oil capable of serving both diesel and gasoline engines is the best choice for your bike.
The high power-to-displacement ratio of a motorcycle engine means rod and main bearings are subjected to loads that are not normally found in passenger car engines. The valve train is also highly loaded, and requires extreme pressure boundary lubrication. The same can be said about gears in the transmission, which are normally lubricated by engine oil. Oil additives containing phosphorus protect these highly loaded extreme pressure areas (in both gasoline and diesel engines). Because diesel engines have higher loading of components, more of the phosphorus-containing additive is present than in typical passenger car oils. And with advanced catalyst systems for gasoline engines, the phosphorus content has been declining in passenger car oils.
Since many bike engines are air-cooled, and tend to be operated at high power outputs and speeds, their lubricating oil needs to be more resistant to high temperature oxidation. That’s another advantage of a premium universal oil. Another thing you want in your motorcycle is oil that has excellent viscosity control, so that with use it retains high temperature viscosity. Some multiviscosity grade passenger car oils, subjected to extreme loads, can quickly thin out. Their viscosity can drop to the next lower grade.
One last thing to consider is whether oil contains friction modifier additives. For improved fuel economy, most passenger car oils have such an additive. But the wet clutch in your bike doesn’t perform right with friction modifiers. Universal engine oils don’t have friction modifiers.
Be careful choosing diesel oils. Not all of them are universal. In addition to the API Service Category CI-4 PLUS for diesels, look for API Service Category SL.
Premium universal oils like Shell ROTELLA T Multigrade are formulated for heavy-duty performance, and your bike engine has some heavy-duty challenges for oil. For optimum performance, be sure your oil is up to the challenge.
For manuals, I use two sources:
1. www.repairmanual.com (they sometimes sell used manuals)
2. www.manualsnmore.com
And there's always E-Bay.
- 83kaw550
That's a big help. I really have no idea when it comes to bikes, particuarily these which are air-cooled. How about Brake fluid and fuel?
- MFolks
As for brake fluids,my shop manual for my 1982 GPz1100 B2 lists D.O.T. 3 but I'd imagine that D.O.T. 4 could be used.
- 83kaw550
- MFolks
The sunlight and ozone degrade the rubber in the lines just like it does on the tires.Motorcycle tires should be replaced every 5 years for the same reason.
Websites for brake lines:
www.spieglerusa.com/cfm/brakelines.cfm
www.helusa.com
www.russellperformance.com/metric_two-line.shtml
www.goodridge.co.uk/motorcycle-brake-lines/kawasaki.htm
Get the covered or coated lines as the bare SS lines act like a slow speed file, rubbing through paint,wires, and other brake lines. Some riders have used heatshrink tubing, others the black 1/4" I.D. electrical spiral wrap as a scuff guard.
When replacing the brake lines, get yourself a hand operated "Mity-Vac", it will make bleeding the systems much easier. Sears sells them and I'd imagine mity-vac has a website too.
- 83kaw550
- Kidkawie
- I bleed premix
- Thank you received: 245
I run a delivery service with a small fleet of Chevy Metros, what most call "throw away vehicles". The oil gets changed every 3k and the filter every other service. I use regular old Citgo 10w30 and a few of my cars have over 300k miles. One of my Dodge vans is almost at 450k.
With my MX bikes I don't buy the $12/liter transmission oil, I use cheap ATF but change it every 3 rides.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- Thank you received: 2098
...Where can I look for parts on these bikes?(new coils)
Click here > www.z1enterprises.com/
- 83kaw550
- RonKZ650
- Thank you received: 240
Well I think my memory may be fading on that model, but 100 percent certain that paint is not original. Oil is pretty forgiving. I don't particularly like the 5w40 Rotella as it shears to a 5w20 in a thousand miles. maybe that does no harm, but I don't like it. The 15w40 oil is cheaper and better.
- 83kaw550
