- Thank you received: 28
Rythmic/cyclical tick - 1980 750 LTD 4 cyl
- TeK9iNe
- What did you do!?!
28 Sep 2010 08:03 #402427
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Rythmic/cyclical tick - 1980 750 LTD 4 cyl
apbling wrote:
As said already, probly a small exhaust leak.
You can use a mechanics stethoscope (or fuel line), to listen around for the source of the sound to help eliminate some things.
Could be as simple as a bit of clutch rattle.
Good luck.
Thanks guys, I'll check that out.
Just seems so weird though how slow the cycle takes. Literally seconds inbetween cycles.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- apbling
- Thank you received: 12
28 Sep 2010 08:39 #402434
by apbling
Replied by apbling on topic Rythmic/cyclical tick - 1980 750 LTD 4 cyl
Thanks guys. I'm in the process of moving, so I won't get a chance to look at this until this weekend.
As for the chain tensioner, I know I have the automatic two wedge system. Want the APE one, but just don't have the cash right now (see above about moving into new house )
- TeK9iNe
28 Sep 2010 12:43 #402488
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
apbling wrote:
You dont need to go to a manual tentioner with that wedge type one, as once it is properly installed/maintained, it cannot push back like the old auto-tentioners did.
Just pull the tentioner out and make sure that it still operates smoothly and there are no notches/nicks anywhere causing it to hang up. lubricate it. Re-install properly (part that connects to engine first, then cross wedge portion), and then rotate the crank around a couple times and it sets itself just fine.
Good luck!
Good luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
