Rythmic/cyclical tick - 1980 750 LTD 4 cyl
20 Sep 2010 12:23 - 20 Sep 2010 12:26 #400354 by apbling
Hi guys,
I noticed an odd noise the other day while riding. At a stop light at idle, I could hear my cams ticking a little bit. Nothing out of the ordinary. Then I heard it get a little louder and then quiet down. Then 4 sec later another cycle, identical to the first. It kept sitting there, every 4 seconds, ticking a bit louder. RPM's unchange and the bike runs fine. BTW, it's a 4 cylinder.
I figured this is really odd, because everything is spinning much faster than the noise was cycling.
Any ideas? Yes, I checked clearances at the beginning of summer, about 2k miles ago and were midrange spec. Oil is 20-40 (or 10-40 can't remember) valvoline motorcycle oil w/ 2k miles on it.
Last edit: 20 Sep 2010 12:26 by apbling.
20 Sep 2010 15:51 #400402 by Vter Bob
Replied by Vter Bob on topic Rythmic/cyclical tick - 1980 750 LTD 4 cyl
Check for exhaust leaks. Also check for a loose spark plug. (Don't ask how I know that)
B)
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
21 Sep 2010 06:37 #400528 by apbling
Replied by apbling on topic Rythmic/cyclical tick - 1980 750 LTD 4 cyl
lol, I won't.
It just seems so weird with the slow cycle rythm....
21 Sep 2010 06:55 #400533 by 650ed
Replied by 650ed on topic Rythmic/cyclical tick - 1980 750 LTD 4 cyl
Instinct (sometimes wrong) tells me it's oil or oil pump related. I would start by changing the oil, it's time anyway at 2k miles, and I would put in Mobil-1 Racing 4T 10W 40 motorcycle oil (see link) to see if problem dissapears. Ed
Oil
21 Sep 2010 07:39 - 21 Sep 2010 08:13 #400541 by apbling
Thanks 650ed.
I was toying with the shell rotella T at wally world too. Some people seem to like it, but I just feel more comfortable putting motorcycle oil in mine. Just gets a bit $ if you put lots of miles on.
This is a synthetic, right?
Would it make any sense to put an oil pressure gauge on that fitting down by the rear brake pedal to see if the pressure changes with the noise?
Last edit: 21 Sep 2010 08:13 by apbling.
21 Sep 2010 16:45 #400675 by 650ed
Yes, it's full synthetic, it has the correct level of ZDDP, and it is made for wet motorcycle clutchs (unlike regular car Mobil-1). I've been using it for several years and it works great in my bike. Ed
21 Sep 2010 21:25 #400752 by gcarson64
Replied by gcarson64 on topic Rythmic/cyclical tick - 1980 750 LTD 4 cyl
i use royal purple max cycle in my kz, runs smooth as you could ask it too. it also runs about 30 degrees cooler too. good luck and have fun riding!
1980 kz550 38,500 miles basket case ( soon to be a BOBBER )
1983 kz550 9,600 miles
1988 jeep grand wagoneer 144,500 miles 4 mpg
25 Sep 2010 22:13 #401863 by kz750ohio
Replied by kz750ohio on topic Rythmic/cyclical tick - 1980 750 LTD 4 cyl
you may want to check the cam chain if the noise continue's after changing the oil. Mine had a noise close to what you are describing and after a couple of months of it the cam chain broke. Very bad thing. I found the automatic tensioner stuck and caused the problem. Since my rebuild I went with the APE manual tensioner and couldn't be happier.
1982 kawasaki kz750 with mikuni carbs bs34, stock everything else.
26 Sep 2010 17:01 - 26 Sep 2010 17:02 #402063 by Kapahulu
Replied by Kapahulu on topic Rythmic/cyclical tick - 1980 750 LTD 4 cyl
+ to what Vter Bob said. It could be a slight leak from the exhaust gasket at the head.
I just had the same problem with my 550 Zephyr. Thought the valves were ticking and realized it was a leak from an exhaust gasket.
2strokeworld.com
Last edit: 26 Sep 2010 17:02 by Kapahulu.
26 Sep 2010 17:23 #402067 by tinlizzie37
Replied by tinlizzie37 on topic Rythmic/cyclical tick - 1980 750 LTD 4 cyl
You may have the old style automatic tensioner, which are junk. My KZ 650 Ltd had one and the chain made an awful noise. I put in one from an 81 or 82. It was a double wedge type,(that can't push in). I've had in for 3 years and it runs nice and quiet. Good luck on finding the cause. I'd still can the old auto tensioner. Bob
Bob KZ 650 E1, En 450
28 Sep 2010 06:33 #402414 by apbling
Thanks guys, I'll check that out.
Just seems so weird though how slow the cycle takes. Literally seconds inbetween cycles.
  • Motor Head
28 Sep 2010 06:56 - 28 Sep 2010 06:57 #402419 by Motor Head
Replied by Motor Head on topic Rythmic/cyclical tick - 1980 750 LTD 4 cyl
I think this Image from the Parts pages will help show you as to whether or not the style you have is the older version.
You can plainly see the difference, as the older style, left bottom, has no wedge from the side.
Last edit: 28 Sep 2010 06:57 by Motor Head.
