Tach Drive Plug?
  • lobstermobster
  • Topic Author
15 Sep 2010 12:38 #398903 by lobstermobster
Tach Drive Plug? was created by lobstermobster
For those not running the tach guage, what do you use to plug the tach drive. Anyone make anything for it?
1981 kz650 w/ flux capacitor
  • testarossa
15 Sep 2010 13:15 #398911 by testarossa
Replied by testarossa on topic Tach Drive Plug?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • mark1122
  • Keep twisting it
15 Sep 2010 13:25 #398913 by mark1122
Replied by mark1122 on topic Tach Drive Plug?
u could take the end off of the cable, insert a block off cap (with a dab of sealant), and thread it onto the stock housing with out the drive gear.
just use your imagination to find something to block the hole in the cap. maybe just cut a disk from a piece of metal ?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Motor Head
15 Sep 2010 13:30 #398915 by Motor Head
Replied by Motor Head on topic Tach Drive Plug?
As far as 1 that is ready to bolt in, try this:
www.schnitzracingstore.com/catalogs/cata...73654&showprevnext=1
Other wise a measurement for a soft Welch/ Freeze plug, probably a buck or less.
15 Sep 2010 13:43 #398919 by 531blackbanshee
Replied by 531blackbanshee on topic Tach Drive Plug?
i made my own.one of the nice things about having a lathe.i just turned down some aluminum stock to the od.of the tach drive and cut an oring groove then robbed the o-ring off my drive and re-used the clamps from the tach drive.
  • testarossa
15 Sep 2010 14:08 #398927 by testarossa
That's exactly what I'm gonna do if my tach doesn't work for me and I wind up with one of those electric speedo thingies.
2004 ZX-10R
Angola, IN
  • mark1122
  • Keep twisting it
15 Sep 2010 14:49 #398933 by mark1122
Ya but u guys are show off's. :P
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • testarossa
15 Sep 2010 15:13 #398940 by testarossa
Ahh Mark, you can always cut out a plug with your trusty grinder. :laugh:
2004 ZX-10R
Angola, IN
  • lobstermobster
  • Topic Author
15 Sep 2010 16:27 #398952 by lobstermobster
Replied by lobstermobster on topic Tach Drive Plug?
I forgot to mention its for a 650? will these fit or is there something else?
  • testarossa
15 Sep 2010 19:02 - 15 Sep 2010 19:04 #399010 by testarossa
The part I linked was for the 900/1000, and it doesn't list an application for a 650. I would have to guess no, but I'm no expert on 650s.
2004 ZX-10R
Angola, IN
Last edit: 15 Sep 2010 19:04 by testarossa.
  • larrycavan
  • Visitor
15 Sep 2010 20:07 #399014 by larrycavan
Replied by larrycavan on topic Tach Drive Plug?
Take the gear shaft out, thread the housing for 6x1.0. Use and allen head bolt with a washer. Loctite the bolt in. Mine's done like that and doesn't leak a drop.
  • lobstermobster
  • Topic Author
16 Sep 2010 20:11 #399227 by lobstermobster
pretty much did what mark said.
took out the plug, removed the gear drive thing. took the screw on cap from the tach cable and pluged that with a shaved down dime with sealant. then used sealant to seal the cap screwed onto the plug. should work.
