- Thank you received: 1
Tach Drive Plug?
- lobstermobster
1981 kz650 w/ flux capacitor
- testarossa
- Thank you received: 82
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- mark1122
- Keep twisting it
- Thank you received: 109
just use your imagination to find something to block the hole in the cap. maybe just cut a disk from a piece of metal ?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Motor Head
- Thank you received: 391
www.schnitzracingstore.com/catalogs/cata...73654&showprevnext=1
Other wise a measurement for a soft Welch/ Freeze plug, probably a buck or less.
- Thank you received: 797
- testarossa
i made my own.one of the nice things about having a lathe.i just turned down some aluminum stock to the od.of the tach drive and cut an oring groove then robbed the o-ring off my drive and re-used the clamps from the tach drive.
That's exactly what I'm gonna do if my tach doesn't work for me and I wind up with one of those electric speedo thingies.
2004 ZX-10R
Angola, IN
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- testarossa
Ya but u guys are show off's.
Ahh Mark, you can always cut out a plug with your trusty grinder. :laugh:
2004 ZX-10R
Angola, IN
- lobstermobster
- testarossa
I forgot to mention its for a 650? will these fit or is there something else?
The part I linked was for the 900/1000, and it doesn't list an application for a 650. I would have to guess no, but I'm no expert on 650s.
2004 ZX-10R
Angola, IN
- larrycavan
- Visitor
- lobstermobster
took out the plug, removed the gear drive thing. took the screw on cap from the tach cable and pluged that with a shaved down dime with sealant. then used sealant to seal the cap screwed onto the plug. should work.
