- Thank you received: 543
How much compression should my 78 KZ1000 have?
- Injected
09 Sep 2010 17:39 #397345
by Injected
Replied by Injected on topic How much compression should my 78 KZ1000 have?
Yep, the 900/100 when cold is very low... the 650/750 seems to be higher - maybe 150... were talking good low mileage motors.
My buddys 900 after it was back from a fresh bore job = 120 cold... it runs like a scalded cat...
- Nelson
09 Sep 2010 20:27 - 09 Sep 2010 20:28 #397376
by Nelson
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
Replied by Nelson on topic How much compression should my 78 KZ1000 have?
here's what I got.
1 152
2 142
3 140
4 150
shows the classic pattern of more wear in the center due to higher temps. I did this cold. Ran the motor about 10 sec just to circulate the oil first and then shut it off.
I'll pull top end and have a look.
1 152
2 142
3 140
4 150
Last edit: 09 Sep 2010 20:28 by Nelson.
- bountyhunter
- Thank you received: 337
10 Sep 2010 00:19 #397397
by bountyhunter
Replied by bountyhunter on topic How much compression should my 78 KZ1000 have?
Those look like pretty good numbers.... even for a 750 twin.:laugh:
- Thank you received: 2098
10 Sep 2010 07:27 - 10 Sep 2010 07:28 #397425
by Patton
Replied by Patton on topic How much compression should my 78 KZ1000 have?
Nelson wrote:
Per FSM for 1978 KZ1000: Standard compression is 128~156 psi; service limit is 100 psi with less than 14 psi difference between cylinders.
FWIW, 1978 KZ1000 came with 26mm Mikuni VM26SS manual slide carbs (not CV carbs).
Stock internals as far as I know. My plan is to put a compression tester on each cylinder. Then hold the CV slide open with my finger and throttle open, hit the starter button and see how hi it will go. What should I get?
Last edit: 10 Sep 2010 07:28 by Patton.
10 Sep 2010 07:34 - 10 Sep 2010 07:38 #397426
by Patton
A leakdown test would help eliminate some of the guesswork.
And as TeK9iNe suggested, assure valve clearances are within specs, this being regardless of compression test results and regardless of leakdown test results.
Last edit: 10 Sep 2010 07:38 by Patton.
- Nelson
10 Sep 2010 09:52 #397465
by Nelson
yes I put on CVs from a 97 police bike a few yrs ago. Very nice power boost for little money! I think it even improved the mileage a little.
At this point I've decided to take off the top and see what there is to see. Then I'll decide how much money to spend.
