How much compression should my 78 KZ1000 have?
- Nelson
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
- Nelson
- bountyhunter
- Thank you received: 337
I would check both dead cold/dry and then also hot. A low reading cold/dry which goes way up with a shot of oil in the plug hole means bad rings. Readings that stay low hot means valves probably need work.
- Polar_Bus
- Thank you received: 7
Stock internals as far as I know. My plan is to put a compression tester on each cylinder. Then hold the CV slide open with my finger and throttle open, hit the starter button and see how hi it will go. What should I get?
Every compression gage will read a little different. My mint condition GPz1100 with 9400 miles on it reads 125 cold. More importantly my engine reads exactly 125 psi for all 4 cylinders.
Bikes:
'84 GPz1100
'06 HD Fatboy
- Injected
- Thank you received: 543
I use to kick start my 650 at 240 psi, but that was a drag only motor.
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- Nelson
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Thanks. it's a very good running engine with 36k miles on it. I'm doing a major custom bike build and trying to decide what (if any) engine work to do. Comp readings will be one of the indicators to help me decide if I should take it apart.
A compression test should be done, no doubt, but if its going to be a major custom bike, it should have a leakdown done no matter what.
Like already said, perform all the major tune-up stuff, especially valves first. Then remove the carbs and exhaust, and put some air in those cylinders. Air will always escape past rings some, and will normally be heard at the crankcase breather. You should not hear any air escaping from the intake/exhaust valves as your tester should indicate.
ME... if it wasnt near new, and hadnt been done by myself recently, then I'm tearing the top off at the very least anyways :laugh:
Good Luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Nelson
- timebomb33
- bountyhunter
- bountyhunter
That is bizarre. I must have been thinking of the 900 (?) or 750 fours but I could swear the full compression was about 170 psi. Even my 750 twin checks in at 155 psi when good.I agree with what "bus" said... cold 110-120 for those motors and as low as 100 they seem to run fine - shockingly low when a lot of motors are 170-180.
