- Thank you received: 2098
Throttle hesitation
Would not recommend heat applied to area surrounding the screw unless the carbs are removed, and float bowl is removed and positively drained of all residual fuel, flushed with rubbing alcohol, and thoroughly dried, before applying any heat. Heat alone to the area surrounding the screw may allow the screw to be loosened. If not, use both dry ice on the screw and heat around the screw.
If replacement screws are available, could as last resort, carefully drill the screws out, using a reverse bit.
- Kingchiefa
- To each thier own.
I apologize for using the word "rebuild" what I should have said was "put back together"
The bike was non-functional and in pieces so I replaced gaskets and pieced it back together. I "rebuilt" the carbs using kits with jets, gaskets, o-rings, etc. Like I said before I'm a bit of a carb novice but they seemed clean to me. I'll have to look into those things you guys said tho about the pilot circuits and what not. Maybe they weren't as clean as I thought.
I cleaned my carbs 3 times in one weekend because of a hesitation problem, of course thinking they were clean and not being 100% positive they were ( I to am a novice with carbs.) I figured the problem was vaccum or fuel line issue. Turns out, my carbs weren't clean at all, there was a slight yellowish tint in the bottom of my bowls that i took as stain because i couldn't get it off, was actually a slime type substance created from geling fuel. Not sure how the guy ended up getting them cleaned but i'm sure someone here can tell us. Also, I don't know the name of the fuel additive, but I was told to add it if the bike is going to sit for a long period of time, like over the winter. May want to look into that also. I would reffer to one of the gurue's though.
1979 KZ1000 ltd b3 Currently in Troy, PA. Hope to some of you on the road.
Fuel Stabilizer is a product added to gasoline in the fuel tank which delays deterioration of the fuel. Allows longer storage intervals.
- jwe2
Everything seems great except that it smokes to beat hell.
I'm hoping this stops after running the bike for a little while, any idea what could cause the smoking? I know oil leaking through the headgasket is possible but I don't want to think about that lol.
- jwe2
- jwe2
Bike pretty much quit smoking after I rode it around for about thirty minutes this evening. All seems to be well except my fork oil must be low. Got a nice hard knock from the front when going over hard bumps. So glad she runs nicely though! So far I've invested about $300 total including the price of the bike, so I think it was worth it!hahah
- jwe2
