- Thank you received: 2098
Throttle hesitation
...serious hesitation when I gave it a small amount of throttle. It hesitated to the point where it would have shut off had I not let off the throttle. I was however able to rev the engine high, it just seemed that under 4k or so rpm it wanted to hesitate/bog down and die....
Imperfect pilot circuits could result in the issue as reported.
[Click on image to enlarge view.]
- jwe2
As far as I know, both breaker-point and magnetic-pulse are both transistorized ignition. My bike has magnetic pulse coils or 'pickups', rather than points.
Yes the bottle I was using for fuel was vented, and I had the other line plugged. Unplugged it would just pull air and the rpms would skyrocket. It's a poor setup, I know. I just did it that way so that I could play with the carbs easier while the engine was running. Instead I will just buy longer fuel hose and hook the tank up properly while leaving it sit on the shelf so I can play with the carbs.
I have a compression tester, not sure if I have the correct size fitting for my bike yet tho.
I apologize for using the word "rebuild" what I should have said was "put back together"
The bike was non-functional and in pieces so I replaced gaskets and pieced it back together. I "rebuilt" the carbs using kits with jets, gaskets, o-rings, etc. Like I said before I'm a bit of a carb novice but they seemed clean to me. I'll have to look into those things you guys said tho about the pilot circuits and what not. Maybe they weren't as clean as I thought.
I've been so sure it was an electrical issue for the longest time, I'm going to kick myself if it turns out to be carburetor related hahah
- KZ250LTD
- Thank you received: 16
- jwe2
- Motor Head
- Thank you received: 391
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- jwe2
- jwe2
- jwe2
- djcody
77 KZ650C airpods and 4 into 2 turn outs exhaust. VM carbs
82 550 LTD all stock except air pods
Been following this thread and I am trying to check my float levels but all the relief screws on my bowls are siezed. Dont know how long its been since anyone turned them. Anyone have a clever way of breaking them? I have applied so much pressure that the brass screws are chipping with the screwdriver.
relief screws :huh: ??
- djcody
