- Thank you received: 1616
1976 KZ 900 #4 plug fouling
- loudhvx
On my twin when the valve seal failed, I didn't see any smoke at all. But a little oil would run down after I turned it off and foul the plug. Only takes a tiny amount to foul the plug and gravity was running it right onto the plug tip.
Could you fix that by moving the side-stand to the other side of the bike? :laugh: :laugh:
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- bountyhunter
- Thank you received: 337
You're laughing, but I was sticking a 1" thick board under the stand when I parked it...... but the valve seat was so gunked up with cooked on oil the valve was not sealing well and compression was dropping.bountyhunter wrote:
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- apbling
- Thank you received: 12
He just texted me and said he is pulling the head to get a look at the valves. Is there anyway to tell if your valve seals are leaking? Also, how do you change them?
Thanks!
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- apbling
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- apbling
Thanks for everyone's help.
- Kidkawie
- I bleed premix
- Thank you received: 245
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- apbling
- Thank you received: 2098
...76 KZ 900...fouling issue on the #4 plug...He said it doesn't smoke at all...has 125 psi on all 4 cylinders....
...head gasket was leaking on a stud or something, but was allowing oil into the cylinder, causing #4 to foul. Seems odd that the compression would be ok, but still be able to leak oil in....
Also odd that it reportedly didn't smoke at all. :huh:
- apbling
in the beginning of my wrenching career I learned AlOT from him. Fast forward 10 yrs, and I think the student hasn't become the master yet, but at least knows whats going on now.
I guess this is the kind of information you can expect through texting/email...
