- Thank you received: 317
Oil and zddp question
- Mcdroid
- Gone Kwackers
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- otakar
:laugh: ZDDP OVERLOAD :woohoo: I believe that stuff is "about" 2400PPM. But that's OK spark plugs are cheap and easy to replace. Provided that the people behind you while you are riding can stand the smell. Most of us don't realize (and frankly don't give a dam) how bad the exhaust stinks behind those of us who use so much ZDDP. :laugh: Even their regular 10w-30 is about 1500PPM (which I believe is more than enough for a V-8 running 6000-revs. :lol:This is what I use...I don't give a crap what others use.
www.bradpennracing.com/Default.aspx
www.bradpennracing.com/Zinc.aspx
GOOOOOOOD stuff. Sort of like feeding candy to your neighbors kid. :laugh:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- larrycavan
- Visitor
That speaks nothing of the actual surface finish on the cam lobes themselves. Some are truly better than others.
Out of all the used performance cams I've had pass through my hands, Andrews has clearly been at the top of the list for worn out lobes.... no matter what oil was used.
You also cannot forget that the oil also is subjected to the forces from transmission gears. It lives a harder life in these old KZ's than it does in car engines.
The requirements for a stock cammed engine are not as severe as they are for a purpose built, high performance street / race motor.
As long as there are flat tappet performance cams being run in both motorcycle and automobile engines, there will be failed lobes from time to time. Simple truth is, it happens. Sometimes it's from improper engine setup and sometimes its just a bad cam that was either not heat treated properly or broken in properly.
There are many factors that come into play where engine component failures happen. IMO it's foolish to not afford yourself any edge you can....
- bountyhunter
- Thank you received: 337
I do know that new engines are made a lot tighter in tolerances than old ones ever were. I was shooting the bull with the master machinist at the shop that bored my head and he said the clearance spec on piston-to-wall for a new BMW was less than one thousandth of an inch. Our old engines are a lot looser.
As for oil: what I read said that for any bearing application, there is exactly one nominal set of specs for (true) viscosity, temp, clearance and bearing load. Done right, the viscosity is just enough that the bearing is riding on a layer of oil and the metal parts don't touch (theoretically). So a tighter clearance probably could run thinner oil.
- bountyhunter
Amen, words to live by.it's foolish to not afford yourself any edge you can....
- MentalMike
- God Bless America!
So what sold you on this brand and why do you stand behind it?
Normally an Amsoil guy myself. but I'm interested.
I swear to God, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity.
1976 Kawasaki KZ900
1978 Kawasaki KZ1000A
1978 Kawasaki KZ650 C
1984 Kawasaki ZN1100 LTD
1985 Kawasaki ZX900A2 GPZ (2)
1985 Kawasaki ZL900 Eliminator
2013 Kawasaki C14 Concours
- bountyhunter
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bountyhunter
The Penn web site kicked out some local places that supposedly carry it here in San Jose. There are probably dealers you can find using their locator. $5/quart isn't bad at all for good MC oil.On the average about $55-$60 for twelve quarts. So about $5 a quart. Not all that bad, all things considered. I pay about $14/Gal for the Rotella 10w-30 at Advance Auto. The ZDDP levels are only an insignificant bit lower in the Rotella but still WAY above the recommended requirements for our engines. That makes it about 30% higher than Rotella. One other thing you must not forget. Since Brad-Penn is not an oil that you can just go and buy, and you must order it, figure another $16/case shipping.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bountyhunter
From what I have seen on a few forums, including the other kawi forum, Rotella is hard to beat for price/performance ratio. They had guys sending it to labs for analysis after 5k miles and it held up very well. I don't recall every reading a negative post from somebody using it.I did find some places semi-locally and called two of them. One wants $7/qt and the other $7.50/qt. Since it is NO better than the Rotella, why should I buy it since I pay $3.50/qt for the Rotella.
