- Thank you received: 225
Output shaft nut fell off!
- Old Man Rock
25 Aug 2010 17:14 #393811
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Output shaft nut fell off!
Sandy... "Yep...it's happened to me too a few times,but I have spares now."...
Spare what, nuts? :whistle: :pinch: :evil:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- toadson
- Thank you received: 1
25 Aug 2010 17:25 #393815
by toadson
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread: kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
Replied by toadson on topic Output shaft nut fell off!
I use teflon chain lube. My bikes been leaving some oil spots when parked though, so I know a seals gone bad.
- Motor Head
- Thank you received: 391
25 Aug 2010 17:44 #393822
by Motor Head
Replied by Motor Head on topic Output shaft nut fell off!
On both my 550 and my 1000 I took the cover off and replaced all4 seals, leak on both was the shifter rod. So far the 1100 has 0 leaks,
- toadson
25 Aug 2010 22:14 #393890
by toadson
Four seals? I was going to change the clutch pushrod seal, output shaft seal, and shifter seal that are in the "mission" cover. I know there are two more for the shifter on the sprocket cover. Is there one more I'm missing?
- bikerjim
- 1986 T-type Regal
31 Aug 2010 09:03 #395199
by bikerjim
1959 Sears moped, 49cc
50's/60's Peugeot moped, 49cc
50's Mustang motorcycle
1959 Royal Enfield Indian Chief, 700cc
1979 KZ750B, owned since new
Replied by bikerjim on topic Output shaft nut fell off!
The pic of that chain looks like the pins are heavily scored and could possibly have weakened. Please consider changing that chain, for my peace of mind.
