- Thank you received: 1
Output shaft nut fell off!
- toadson
Has this ever happened to anyone before? I'm thinking of using loctite on it after I change out the leaky output shaft seal, but don't know if I should get another original lock washer or try something different. Any suggestions? And how hard is it changing the output shaft seal? I imagine its a bit of a job.
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread: kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
- Old Man Rock
- Thank you received: 225
I learned, the hard way of course :blush: , to use Blue locktite when installing it back on... Also, insure the washer tab isn't broken off for this is what occurred in my case. Torques for 104 ft pounds....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- RonKZ650
- Thank you received: 240
- TeK9iNe
- What did you do!?!
- Thank you received: 28
When time for removal, an impact wrench works fine with a little twist of the socket with your hand, no biggie.
Changing the output shaft seal is a piece o' cake if I remember correctly. You just pry the old one out, then grease the new one, and use a hollow pvc pipe/dowel to evenly rubber mallet the new one in.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- OKC_Kent
- Thank you received: 20
But red loctite will assure that you will need a torch to heat the nut up, 6 foot pipe for the large socket and two teenage boys to hold the bike down as you put everything you have onto the end of said pipe. I wish I had an impact wrench that day. :laugh:
I would just use a new tabbed washer and maybe some blue loctite.
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- timebomb33
I THINK MY POWERBAND BROKE
- toadson
The nut and washer. Only one or two tabs are bent on it.
This is where they were sitting.
Greasy mess
My chain has some scuff marks now too.
A little damage here.
Not sure if I will reuse this washer or not. I don't see why I couldn't, since it fits the splines. I will use some loctite for sure for cheap insurance. I'm going to clean everything up nice and replace that seal for sure.
- hocbj23
- Visitor
- Thank you received: 2098
...Not sure if I will reuse this washer or not. I don't see why I couldn't, since it fits the splines....
kawasaki.com shows the special washer is still available, part no. 92200-1065, used on a host of various models.
- Sandy
- Fly High,Tony
- Thank you received: 13
1977 KZ1000 A-1
- timebomb33
